fuel draining back into tank
Old Nov 7, 2012 | 05:46 PM
Gorts 5th's Avatar
Smile fuel draining back into tank
my fuel is draining back into the tank after she sits for a few hours or overnight so in the morning i got to re prime the fuel system by cranking her its annoying i am thinking an purchasing the mr gasket micro electronic fuel pumps they are 40 buck in stead of the 150 200 pumps i see available and they are available at the local parts store
has any one used these pumps or should i go with the oem replacement fuel pump im currently using one for a 360 on my 318 i don't have any fuel starvation issues with this pump i just think its the cause of the drain back to the tank
any input would be appreciated
Old Nov 7, 2012 | 07:37 PM
Mr.4spd's Avatar
Yeah, shouldn't there be an anti drain back valve built in? Perhaps it's smoked.
Old Nov 7, 2012 | 08:38 PM
Gorts 5th's Avatar
would that be in the tank or the fuel pump
Old Nov 7, 2012 | 10:49 PM
Is there some reason you cannot use proper punctuation so the rest of us can read what you type?
WHAT ARE you working on? 46 Stude? Farmall tractor?
Post 70's some kind of ?? Mopar?? If so, how about putting that down.
YOU MIGHT have a situation where the tank is improperly vented and causing a vacuum, especially when it cools down at night. Try leaving the cap loose overnight and see if that affects the problem. If you have a car which originally had a carbon canister under the hood, the system may have problems. If it's been removed, you may not have a vent for the tank at all
Modern gas is a real problem, it seems to boil and evaporate easier, and many guys are having similar problems.s
LISTEN as your remove the cap and see if the tank appears to be under pressure/ vacuum
I did three things on my 67 which greatly helped vapor lock/ fuel boiling problems
1--installed an electric pump back at the tank and removed the mechanical pump
2--installed a vapor return system, using a Wix filter with a built in orifice. Google up Wix 33040, 33041, 33054
3--Bought a (3/8?) or thicker insulator gasket under the carb.
Old Nov 8, 2012 | 08:01 AM
Charlie72's Avatar
Unhappy
Originally Posted by 440roadrunner
If you have a car which originally had a carbon canister under the hood, the system may have problems. If it's been removed, you may not have a vent for the tank at all.
My mechanic just removed the carbon canister from my 72 Charger SE. How big of a problem did we just create? Can I simply have him re-install it? He said it was dripping fuel when he removed it and it was a fire hazard.
Old Nov 8, 2012 | 09:21 AM
You can dowload a 72 shop manual for free in this thread:
http://www.forabodiesonly.com/mopar/...al%2C+download
The link:
http://www.abodyjoe.com/pictures/Mis...1%20wiring.pdf
Here's a functional diagram from the 72 manual:
You must be VERY careful if you remove this as you can create a situation where the tank is not vented. The filler caps are "pressure vacuum" only meant for safety, IE release pressure or let in air at a predermined pressure.
Your 72 I believe has a separate vapor can (in the trunk?) which was incorporated into the tank in later years. THE ONLY VENT is the 1/4" line to the front which hooks into the rest of the carbon can system.
The "overfill limiting valve" should be at the very end of the 1/4" line up front, and could be rusted shut
Old Nov 8, 2012 | 10:56 AM
Gorts 5th's Avatar
Smile
its a 86 chrysler 5th ave M body, i removed the canister about a week ago, but i never had it hooked up to the system other than the vent line, the canister is under the hood.
but it was draining be for that it just seems to be getting worse,
the vent to the tank that was on the canister is still open my fuel filter has the small return tab on it to allow the unused fuel to return to the tank when running the engine/wix filter.
i just did some work on it today and the 2nd fuel filter which is clear was empty.
i run the oem with the return first then farther up the line i use a clear filter these are all after the mec. fuel pump.
i thought the fuel pump kept the line primed.
i can get the before mentioned electric pump for $40 at the local parts store, or should i replace the mechanical pump?
if the mechanical pump is supposed to keep the system primed i would just replace it, i picked one up this morning but im waiting on some good advise here before i replace it.
if it is a plugged vent system a fuel pump wont change the situation.
i will look closer at the system around the tank before i install a new pump.
Old Nov 10, 2012 | 07:17 PM
Gorts 5th's Avatar
Smile
OK i installed the electric and the mechanical fuel pumps;
Any input here would be good?
i have run the car it's richer in its fuel mix the idles up about 50 rpm.
there is a location behind the right front wheel up in the frame where the fuel lines turn up into the engine compartment i located the electric pump there, the mechanical pump is for a 360 2bbl when i fired the whole system up it would not prime with out me cranking the engine once the electric got primed you could hear it.. then she fired up.
In the morning the filter was emptily again but when i turned on the ignition it took only a few seconds for the pump to prime up and when i cranked her she fired up big improvement.
Pondering the fuel system i think i need some type of check valve on the small vent from the charcoal canister to prevent the tank from depressurizing so as not to drain the fuel line empty?
i'm assuming the system needs to be sealed.
any input?
Old Nov 11, 2012 | 01:58 AM
MrOldart2U's Avatar
So you changed the mechanical pump and added an electric? Or did i misinterpret? If its for sure draining the carb, I would check the needle and seat in the carb, Thats what keeps gas in the carb. Todays fuels are more prone to evaporation/boiling away, especially during a 'heat soak' cycle. The fuel tank doesnt 'pressurize', but maybe needs a different type of cap. (vented vs non vented, or vice versa). Also if you are going by one of those 'see thru' filters they can be deceiving also.....
Old Nov 19, 2012 | 06:35 AM
Gorts 5th's Avatar
Smile
it's not so much the float bowl is draining down;or that boil's off its the fuel lines from the tank that have me puzzled?
and yes i did install a electric pump before the mechanical pump i have been running it for about 30 miles, so far no problems i don't have to crank her as like before to get the fuel lines from the tank primed.
i'm amusing that the fuel filter with the with the small return stem on it is why the fuel lines are bleeding down to a point but what will cause it not to hold fuel back to the tank on the supply side of the system?
is that a defective mechanical pump or /fuel leak in a line, or at the in tank plumbing ?
Old Nov 19, 2012 | 12:26 PM
I would check all of the rubber lines at the tank for cracks. The tank connector that the lines connect to could be rusted out ??
Old Nov 19, 2012 | 06:06 PM
Gorts 5th's Avatar
Smile
i suppose it's time to check the tank or should i say drop it and check it i will get up under there to marrow and see what i can see
BMiller
18
Dec 18, 2013 09:31 PM
cuda66273
Mar 1, 2010 07:34 PM
3x2v
Aug 9, 2009 07:28 PM
68camperspecial
Jul 23, 2009 03:55 PM
mopar528dakota
Jun 17, 2008 03:58 PM
