pulley removal
Old Nov 18, 2012 | 12:30 PM
castillo70's Avatar
pulley removal
ok i feel like an idiot, i cant seem to figure out how to remove 440 crank pulleys . ive never had one off before. looks like they just slide over crank end, mine has keyway with no key . other than the torch and maul im lost. any help would be great.
Old Nov 18, 2012 | 02:03 PM
Chryco Psycho's Avatar
6 bolts hold the pulley on the damper , once the pulley is removed you need a 1.25 " socket to remove the bolt & a puller to remove the damper
Old Nov 18, 2012 | 03:04 PM
castillo70's Avatar
ive already did that. cant get the pulleys of the balancer. i dont know if its rusted on or what . just didnt want to go banging to hard on it with knowing for sure.
Old Nov 18, 2012 | 03:39 PM
Just tap a screwdriver or chisel between the damper & pulley , it must be rusted in place
Old Nov 18, 2012 | 07:10 PM
castillo70's Avatar
ok ill try that. ive been taping. i got it soaking in a little penetrating tonight. i'll let u know how it goes in the morning. thanks
Old Nov 18, 2012 | 08:21 PM
Be careful soaking it You could damage the rubber connecting seal IF you have the bolts out ? Just hit it with a hammer
Old Nov 18, 2012 | 11:31 PM
don't bend the pulley though
Old Nov 21, 2012 | 06:21 AM
castillo70's Avatar
finally got it . took the torch and larger hammer. screwed up pulley,other than that its off. man it was stuck hard. oh well. think it was a a/c set up. it had four belt grooves i have another 2 groove i will use non a/c.
Old Nov 21, 2012 | 06:47 AM
Gorts 5th's Avatar
Smile
wow that's too bad what was it rusted to the crank bolt washer?
Old Nov 21, 2012 | 06:23 PM
castillo70's Avatar
heck i dont know why it was so tight. seems like alot of corrosion behind the pulley to balancer bolts. i kept tapping lightly not to damage the pulley. finally said to hell with it and put the heat to it. still wouldnt break loose. finally i just slammed it, did just what i thought . bent the pulley but came off flying through the shop.
flathead31coupe
Mar 27, 2010 02:48 PM
Cracocuda
Oct 9, 2009 05:40 PM
Cracocuda
Aug 29, 2009 06:04 PM
Andre11
Aug 26, 2009 05:11 PM
multi-lebaron
Mar 26, 2008 07:07 PM
