Hard start when hot
Old May 14, 2018 | 10:47 AM
Dane Trask's Avatar
Hard start when hot
I have a 360 with a mild cam, Edelbrock 750 on a Weiand intake. After running the intake gets so hot it is vaporizing the fuel in the runners and carb. I have a heat spacer already, but it is bad. When I stop, if I take the aircleaner cover off it looks like fog coming out of the carb.
Old May 14, 2018 | 11:31 AM
Are you sure the cooling system is in good order?
also check and make sure the engine timing is set correct.
Old May 14, 2018 | 11:33 AM
Also check to make sure your not over fueling or flooding everything.
Old May 15, 2018 | 03:56 AM
What are you using for fuel, e10, e15 or regular unleaded? Fuel evaporation is a problem with the Edelbrock carbs especially when alcohol fuels are used, the alcohol evaporates faster and at a lower temp than gas.
Old May 15, 2018 | 03:59 PM
Dane Trask's Avatar
OK, after reading a bunch of posts on this issue, I bit the bullet and pulled the intake off, blocked the exhaust crossover, and sealed everything really well. I went back to the 600cfm carb, set the timing at 21/36 and some fresh non-ethanol gas. Things are looking up. I suspected I had a vacuum leak at an intake port, thus causing a rough idle and erratic vacuum. It turned out so. The vacuum is much better at 15 and fairly stable for a mild cam. And the hard start issue is much better.
69ChryslerNewportCustom
Jan 16, 2018 05:44 AM
73landyacht
May 9, 2015 04:24 AM
A-Mac555
Aug 26, 2014 10:53 PM
duster3
Feb 13, 2013 10:24 PM
mblackmon
May 17, 2012 12:12 PM
