headers, worth it?
Old Jun 16, 2015 | 12:57 PM
celt69's Avatar
headers, worth it?
I have a beautiful set of jet coated exhaust manifolds on my '67 440 Belvedere and I know the previous owner HAD a set of headers on it at one time but felt they were too troublesome to be worth it. Every other performance car I have owned I had put headers on.
I would like to add a GOOD set of headers and add an x-pipe while at it, thoughts, experiences? Are headers on the 440 really worth it? I am at 452ci and am not lacking any power! Am I just asking for more hassle than it is worth?
Old Jun 16, 2015 | 01:25 PM
Drag Pak's Avatar
If you add headers, TTI are really the best / only route to go , but expensive.
If you are not going a competitive drag racing route, it is a waste of time, money and frustration.
My $0.02
Cheers
Peter
Old Jun 16, 2015 | 01:31 PM
celt69's Avatar
My $0.02
Cheers
Peter
Thanks Peter, that is kind of what I was thinking. Car is a Super Stock clone and won't see a track, just a Saturday night special to have some fun and make some noise with. Not sure I want the frustration. I was looking at the TTI site and was thinking of their dual exhaust system with x-pipe for exhaust manifolds. The previous owner had put a cheap dual system in but it's missing hangers and just not real nice.
Old Jun 17, 2015 | 07:50 AM
You can still make good power with factory manifolds.
But, what compression does your motor run?
Old Jun 17, 2015 | 09:29 AM
DDodger's Avatar
My opinion, depends on use and power level. If this is just a warmed up street build and the manifolds are one of the HP series engines then you might not gain much to be worth the trouble.
Old Jun 17, 2015 | 03:18 PM
celt69's Avatar
Compression runs 9.7:1, 0.060 over 440, steel crank, forged pistons, ported 915 heads (75cc), Comp Cams 292H, Victor single plane with 800cfm Eddy (looking at switching out to a Holley), 727 with 2800 stall, 3.91 with sure grip.
Runs strong.
Old Jun 17, 2015 | 03:19 PM
celt69's Avatar
See my other post DDodger, I am thinking based on comparable builds I have seen that I must be CLOSE to 500HP currently? 450 anyway...??
Old Jun 17, 2015 | 04:28 PM
Back in the early 80s I had a mild 440 in a 65 Jeep 2wd pick up, DC hemi cam, Holley 750 and aluminum intake with 69 hp manifolds the truck ran 14.20. I found a used set of Hooker 2" headers that fit and with no other changes than a number or two in the primary jets, the old heap ran 13.60s. Yes you could feel it around town and yes it was worth it!
Old Jun 17, 2015 | 08:08 PM
moe7404's Avatar
i had a new 1977 100 pick up. 318, auto. i put headers on it. i had to pull the starter out half way and jam it there to get the header in. it was hard to seal to the head. and the head had a 3/16 hole for air injection that i had to plug. they was noisy. for mild street engine its not worth it. and most headers dont give that much power at low speeds, where most of your driving is.
Old Jun 18, 2015 | 01:45 PM
ctreser's Avatar
If you want to save $150 - $200 you could go with Dougs headers. I just put a set on my 66 Coronet with a 440 and they fit like a glove and are of top quality.
Old Jun 18, 2015 | 02:13 PM
celt69's Avatar
I had been looking at those as well, they looked good!
Old Jun 19, 2015 | 02:21 PM
Archer's Avatar
celt -
With those specs, despite claims to the contrary, you'll need a free flowing exhaust to optimize performance and that starts with headers, an "X" pipe and good mufflers. And lets be honest, they just look and sound better.
I have about the same set up, and am using old school Hooker headers with 1 7/8" primaries and 2.5" custom pipes. HP based on track times is in the 500 range.
Old Jun 19, 2015 | 02:50 PM
TTI Headers and SpinTech Performance Mufflers...Hands Down!!..
Old Jun 22, 2015 | 02:46 PM
celt69's Avatar
Who is the best vendor to buy TTi from (would like to support vendors on the board if possible)? Keep in mind I am in Canuk land so Canadian vendors are easier but having said that everything I have purchased to date has come straight from JEGS, Summit or YearOne. Duty and exchange kills me but after you consider inflated prices on this side of the border it is pretty much a wash. Might be time to make use of my wife's dual citizenship and make a move
Old Jun 22, 2015 | 06:14 PM
Drag Pak's Avatar
Best to order direct from TTI. They may have a complete exhaust kit for your car.
Call them, send them a bank draft, and you are good to go.
VERY NICE! VERY BEST!
BUT EXPENSIVE!!!!
www.ttiexhaust.com
The vendors just mark them up accordingly!
If you can find a "Canada Customs Bonded Carrier"
"Canada Customs Sufferance Warehouse" near you, it will save you a ton of money!
I am in Victoria and use Seawings Express. They pick up product in Blaine and courier it to Victoria for a minimum charge. You do your own customs clearance etc.
Old Jun 23, 2015 | 06:47 PM
Sounds like a good suggestion...
Old Jun 23, 2015 | 11:47 PM
celt69's Avatar
BUT EXPENSIVE!!!!
www.ttiexhaust.com
awesome idea Drag Pak! I am in Kamloops but with a little planning I could easily combine that with work trip etc. to the lower mainland. I may have more questions for you later re: Seawings.
Old Jun 23, 2015 | 11:49 PM
celt69's Avatar
agreed, seems like a no-brainer
Old Jun 25, 2015 | 04:20 PM
xaza's Avatar
If the previous owner stuck in a junk exhaust then I would expect the sound to suffer as much as performance. I would say replace it for the quality sound and enjoy any performance gain you get as a bonus. I agree with Archer that any good dual exhaust is going to start with a x pipe. My 360 really woke up when I replaced it's exhaust, like finally feeling the mods do more than reduce my mpg. I don't understand, how were the headers too troublesome for the previous owner?
Old Jun 25, 2015 | 11:49 PM
celt69's Avatar
Leakage, starter and plug access.
Dave E
36
Oct 8, 2013 01:22 PM
ruffinracin121
Nov 20, 2007 06:53 AM
cudakid69
Nov 9, 2007 08:08 PM
4004speedrunner
Nov 6, 2007 12:05 AM
ruffinracin121
Oct 29, 2007 08:32 PM
