help with a 360
Old Oct 25, 2012 | 08:10 PM
onthewater66's Avatar
help with a 360
i have a 1988 that is rust seized and would like to just replace the motor.. problem is i need to use the intake, distributor, and exaust manifolds from the 1988... anyone know what year motors i can use? i can get some used 1990s running engines cheap..
Old Oct 25, 2012 | 09:33 PM
"I don't know" You have to be careful. There are the earlier flat tappet LA engines, the late 80's "roller blocks" and then the magnum head engines.
Here:
http://www.allpar.com/mopar/LA-V8-en...ead-swaps.html
Old Oct 26, 2012 | 05:22 AM
Gorts 5th's Avatar
Smile
are those 80 s roller blocks anything special other than the roller gear
Here:
Old Oct 26, 2012 | 05:25 AM
Gorts 5th's Avatar
Question
why do you have to use the intake and exhaust manifolds is this motor emission controlled how did this block get seized with rust
Old Oct 27, 2012 | 05:36 PM
the 360 is a marine application.. i need the use the intake, exaust manifold, cam, and distributor from the old motor. cam is due to the fact i need the motor to spin the opposite rotation. the motor is fresh water cooled (has green antifreeze) so i do not need marine head gaskets and freeze plugs. but from the info 440roadrunner gave me i opted to go with a 1987 360 out of a low mileage pickup.. thanks guys
Old Oct 27, 2012 | 07:20 PM
Did you ever try and free up the old motor ? My family had a ski boat sat for years and motor froze 4 cyl chevy motor Ran fine afterwards
Old Oct 28, 2012 | 06:16 PM
i tried to free it up with mystery oil.. no luck pulled heads... alot of rust.
Laura Cullen Reynolds
Apr 22, 2024 03:24 AM
jej
Nov 17, 2014 07:59 AM
notta _mech
Sep 13, 2011 09:42 AM
keith811
Jan 13, 2011 10:43 AM
choelzer
Feb 29, 2008 03:00 AM
