help with a 360
Old 10-25-2012, 08:10 PM
onthewater66's Avatar
help with a 360
i have a 1988 that is rust seized and would like to just replace the motor.. problem is i need to use the intake, distributor, and exaust manifolds from the 1988... anyone know what year motors i can use? i can get some used 1990s running engines cheap..
Old 10-25-2012, 09:33 PM
"I don't know" You have to be careful. There are the earlier flat tappet LA engines, the late 80's "roller blocks" and then the magnum head engines.
Here:
http://www.allpar.com/mopar/LA-V8-en...ead-swaps.html
Old 10-26-2012, 05:22 AM
Gorts 5th's Avatar
Smile
are those 80 s roller blocks anything special other than the roller gear
Here:
Old 10-26-2012, 05:25 AM
Gorts 5th's Avatar
Question
why do you have to use the intake and exhaust manifolds is this motor emission controlled how did this block get seized with rust
Old 10-27-2012, 05:36 PM
the 360 is a marine application.. i need the use the intake, exaust manifold, cam, and distributor from the old motor. cam is due to the fact i need the motor to spin the opposite rotation. the motor is fresh water cooled (has green antifreeze) so i do not need marine head gaskets and freeze plugs. but from the info 440roadrunner gave me i opted to go with a 1987 360 out of a low mileage pickup.. thanks guys
Old 10-27-2012, 07:20 PM
Did you ever try and free up the old motor ? My family had a ski boat sat for years and motor froze 4 cyl chevy motor Ran fine afterwards
Old 10-28-2012, 06:16 PM
i tried to free it up with mystery oil.. no luck pulled heads... alot of rust.
Laura Cullen Reynolds
04-22-2024 03:24 AM
jej
11-17-2014 07:59 AM
notta _mech
09-13-2011 09:42 AM
keith811
01-13-2011 10:43 AM
choelzer
02-29-2008 03:00 AM
Quick Reply: help with a 360
