Help running a new 440
Old Mar 9, 2020 | 03:20 AM
aatkinsonalexdatkinson's Avatar
Wonder if someone can help with a newbie question on how to tune a newly rebuild engine. I’ve messed about with engines in the past but never tuned an engine from new.
I have a mopar 440 with some mild edelbrock upgrades (performer cam / heads). I’ve just run the cam in and am looking to set the engine to run properly
I also have a new 1406 edelbrock carb and MSD ready run distributor fitted as well as an innovate air fuel ratio wide band sensor.
At the weekend I was playing around with the timing and idle setting and idle mixture screws but was doing it methodically. E.g. I set the static timing, adjusted the idle, this then changes the timing and so on. Can someone give me a steer on the step by step process for setting timing and carb?
Old Mar 9, 2020 | 11:24 AM
Set the base timing to 12*
Set the advance to 28* @ 2500RPM
Adjust the carb in gear @ Idle (750-650RPM)
Adjust Idle Air Mix Screws in gear... Screw in till it stumbles. Then turn out till it runs smooth and the add in one Full Extra turn.
Then go drive the **** out of it !!
Readjust when the weather changes...
Mopar on !!!!
440Aspen
25
May 19, 2015 12:14 PM
mrzods13
Jun 16, 2014 03:05 PM
twalace
Jun 26, 2012 12:02 PM
cougar9500
May 29, 2012 02:15 PM
auerdoan
Sep 8, 2011 09:29 AM
