Holley Carb Help..
Old Sep 23, 2014 | 04:51 AM
Robert Weaver's Avatar
Question Holley Carb Help..
I've got a Holley Carb and just wanted to know what the 3 small lines (2 Back, 1 pass Side) go to? Just want to make sure I've got Hooked up correctly.
http://www.rockauto.com/catalog/more...175&cc=1079647
{#H22245} Holley 2 Barrel; Reman
2BBL; Engine VIN K; H2-2245
Old Sep 23, 2014 | 06:04 AM
Check the Vacuum Diagram for your application....
But more than likely...PCV, Vac. Amplifier on valve cover, Underdash, Sources..... For what it's worth...
Old Sep 23, 2014 | 06:24 AM
K, so the vac adv line either goes on the line on the pass side or one of the small ones on the back right?
Old Sep 23, 2014 | 11:41 AM
More like this.. See Figure #13 .. http://www.autozone.com/autozone/rep...00c152800529fb
But if it's Ported You can use it....
Old Sep 23, 2014 | 12:43 PM
Ok, I included 3 pics of the OLD Carb of what I'm curious bout. Just wanna make sure I've had things hooked up correctly.
Also, which slot does the Arm on the drivers side go? The car is an Automatic.
http://www.forbbodiesonly.com/moparf...6&d=1411559165
http://www.forbbodiesonly.com/moparf...7&d=1411559181
http://www.forbbodiesonly.com/moparf...8&d=1411559192
Old Sep 24, 2014 | 07:14 AM
Updated links with pics.
Old Sep 25, 2014 | 08:05 PM
Anyone?
Old Sep 25, 2014 | 08:26 PM
OK... Whats he application.... I'll see if I have the info in the shop tomorrow..
Old Sep 26, 2014 | 04:13 AM
74 Charger SE 5.9 360 LA
Old Sep 26, 2014 | 05:40 PM
ok... Heres what I got for you....
1. Air Amplifier
2. 2nd in from the furthest outside.
3. Dist spark delay
Old Sep 26, 2014 | 06:07 PM
Is the dist spark delay the 3rd pic?
Old Sep 27, 2014 | 07:07 AM
I would say yes... But check it with a vacuum gauge...
No Vac at idle
Vacuum off idle
TimN8er
Jun 20, 2012 06:13 AM
scott2683
Mar 11, 2011 01:16 PM
mopsled
Dec 20, 2009 06:43 AM
Henrius
Nov 11, 2009 06:51 PM
dotman
Nov 30, 2008 11:36 AM
