Magnum Lifters
Old Feb 19, 2020 | 06:36 PM
rhoole93's Avatar
Magnum Lifters
I'm installing magnum heads on an LA block.
The LA block was a factory roller cam engine. I have all the original hardware from the block used with the roller lifter ie. The "spider" and the lifter "retainers" if thats what theyre called. Can I reuse that hardware and just throw a set of factory magnum roller lifters in? I dont want to use the retrofit lifters with tie bars if I dont have to.
Old Feb 20, 2020 | 02:11 PM
I think the lifters will uncover the oil galley in the lifter bore.
Old Feb 21, 2020 | 06:52 AM
I agree with you Bob.
Old Feb 27, 2020 | 11:27 AM
BillK's Avatar
Late to the party and maybe I am missing something here but . . . if it is an original roller cam block why would you not be able to use the stock type roller lifters ?? The lifters are the same part number for the 318 and the Magnum 360. Maybe if you were doing some type of huge camshaft but otherwise I dont see any reason why not.
Old Feb 28, 2020 | 04:13 PM
LA Block / Magnum Roller lifters.... You better check it. I think it needs retro lifters or Lifter Bore Bushings.
Please correct me it i am wrong.
Old Feb 28, 2020 | 04:33 PM
BillK's Avatar
If his block was originally a roller block like he says in his original question then it will work fine.
Old Mar 5, 2020 | 06:38 AM
rhoole93's Avatar
I talked to Hughes. They told me its totally fine to use stock stock magnum lifters in a factory LA roller. Thanks guys.
Old Mar 6, 2020 | 09:41 AM
maca
Apr 17, 2015 08:02 PM
maca
Jul 10, 2014 08:21 PM
q8_barracuda
Dec 30, 2011 04:30 PM
bugy
Feb 1, 2011 08:51 AM
ryan_e
Aug 18, 2009 11:50 AM
