mopar 360 dodge ram
mopar 360 dodge ram
i have a 85 360 small block i am wanting a to know about how much horse power it will produce i have an xe268h cam with 477 480 lift 264 duration a edelbrock performer intake holley 4barrel 650cfm mechanical secondarys k&n airfilter with hood scoop summit truck headers dual 2.5 exhaust it has a518 tranny with stage 2 shift kit and dana 60 4.10 gears its going in a 85 dodge ram thanks ahead of time
Not sure how much you would like to get but I have heard that the heads can be restrictive. Maybe look for a set of J or X heads to rebuild and swap on at the same time. I believe that those are the letter code for the good heads, I may be wrong though.
A light touch-up of any sharp edges and a port match dosn't take much time and will help. Aggressive porting should go along with bigger valves, then a compression increase with pistons, your getting into the Hot Rod engine territory.
With smallish ports and valves the velocity is higher creating your low end torque. It really depends on your useage and where you want to make power.
I would only use that manifold if it was a stock cam and untouched heads, anything more will be choked off. The cast iron Mopar 4bbl manifold would be good on the 360, the Edelbrock Performer would be best. Stay away from the RPM series.
rearl9
Oct 19, 2012 07:34 PM
dealrocker
Feb 1, 2010 08:39 AM
