Mopar 440 - BAD SOUND!?!?!?!
Old Sep 24, 2014 | 04:57 AM
hckrphil's Avatar
This is a mopar 440, bored .30 over, complete fresh build with about 300 miles on it. I just had it tuned up, timing adjusted, carb adjusted....... choke adjusted....... seemed to be running GREAT. Prior to tune up, my timing was off and I was running hot..... after being adjusted, I've been running at a perfect 180 constant.
I just changed the oil, oil levels are great, and as I'm out for my "test" drive after the oil change, this sound started:
I originally thought no big deal, maybe my new water pump went bad...... so I disconnected the belt to the water pump, and it is still doing it.
I'm at a loss.......and the bank account is wearing thin after the cost of this build, tuning, blah blah blah.
Any ideas where I should be looking first?
Thanks!
~Phil
Old Sep 24, 2014 | 05:23 AM
Tough one, I'd check bellhousing area, anything loose, is starter gear disengaging?
I hope it's back there.
Old Sep 24, 2014 | 05:34 AM
hckrphil's Avatar
The starter gear not disengaging would make sense... good place to start looking anyways I suppose.......
That could make a whiring noise with the occasional tink? I'll have to check that first when I get home...... thanks for the idea!
Old Sep 24, 2014 | 08:02 AM
Little to grabbled for me to catch.... Sounds like it comes and goes?
Noise is still there with all the crank drive accessories unhooked?
Old Sep 24, 2014 | 08:16 AM
hckrphil's Avatar
The sound does come and go. The sound is still there after I've removed the belt from Crank > Water pump > alternator.
Old Sep 24, 2014 | 08:45 AM
These videos never "do it" for me
Check or remove the dust shield, you should be able to SEE the starter gear
This an automatic? check the converter bolts
Other than that I don't know.
Old Sep 24, 2014 | 09:03 AM
moe7404's Avatar
could it be a bearing. but not an engine bearing. here is a history note. Chrysler invented the Oillite bearing. its a good read. http://en.wikipedia.org/wiki/Oilite
Old Sep 24, 2014 | 09:59 AM
hckrphil's Avatar
This was a spur of the moment video.....the exhaust is loud in the car making it more difficult to diagnose... Pulling out a stethoscope tonight... Stay tuned!!
Old Sep 24, 2014 | 12:56 PM
Drag Pak's Avatar
Cam sprocket/chain hitting cover?
Old Sep 24, 2014 | 01:49 PM
My vote is for a loose converter bolt.
Edit :: I see you found the problem THAT CAM BOLT MUST BE installed with locktite !!!!!!!
Old Sep 24, 2014 | 05:33 PM
hckrphil's Avatar
Looked into this with a stethoscope tonight.... Something has literally blown up behind my timing cover...tearing it down tomorrow night... Atleast this should be a relatively easy fix without having to pull the motor... More to come after I get this opened up!!
Old Sep 24, 2014 | 06:00 PM
Good Luck, fingers crossed.
Old Sep 25, 2014 | 04:08 AM
hckrphil's Avatar
As we were running the motor to diagnose it......... you could literally hear it self destructing.... We had the stethoscope directly on the timing cover and it was clear as day....we turned the motor off immediately... more to come after I get out of work today....... oh the anticipation!
Old Sep 25, 2014 | 06:46 PM
hckrphil's Avatar
Problem Figured Out!!!
OK, figured out the problem!!!!!!!!
Here is what happened.... Back when I first put the newly built motor in the car, I was having heat problems...
I had an underdrive aluminum pulley on the crank which I thought was not spinning the water pump fast enough..... so I bolted the STOCK crank pulley back on...... however, when I did, I used the bolts that were off the aluminum pulley..
Little did I know these bolts were TOO long for the stock pulley. When I screwed the pulley on with these bolts, they went THRU the harmonic balancer, gouging the timing cover. When I tired to start the motor when this happened, it was so gouged in there the motor wouldn't even turn over.
I finally figured that out, but at that time, apparently the damage was already done. At this time, I had no idea I had done any damage...... well, until this noise started.
When I gouged the hell out of the timing cover, it shoved the gasket IN towards timing chain......
Eventually the chain / gear must have started eating away at the gasket, and eventually yanking it into the timing cover completely.
Luckily, when this happened, I caught it right away..... it looks as if the only damage was to the timing cover and gasket.
Talk about a close one. New gaskets and cover have been ordered and should be here Monday for re-assembly. Live and learn I suppose! My fault completely!
See the attached photos!
~Phil
Attached Thumbnails Mopar 440 - BAD SOUND!?!?!?!-timing_cover.jpg   Mopar 440 - BAD SOUND!?!?!?!-timing_cover_gasket.jpg
Old Sep 25, 2014 | 07:47 PM
Glad it wasn't worse, good lesson for everyone.
Old Sep 25, 2014 | 08:39 PM
I agree.... Thanks for sharing !!!!!!!
"A lessen taught, is a lesson learned" Thats what I say anyway.....
Old Sep 26, 2014 | 05:37 AM
pro-tech's Avatar
Good find, I am assuming you meant to say seal not gasket...Thanks for letting us know what you found...Bill
Old Sep 26, 2014 | 12:18 PM
Myraman's Avatar
Thanks for the info! Good luck with the new parts going back on. That was a close one!
Old Sep 27, 2014 | 06:15 PM
hckrphil's Avatar
Yes... crank seal, not gasket
Now I'll get it all back together, and flush the motor a dozen times to make sure nothing is floating around anywhere that it shouldn't be!
timmie124
Sep 9, 2010 08:21 AM
Moparknighthawk
May 22, 2010 09:10 PM
Barfly
May 17, 2010 08:45 PM
CantRamItDodgeIt91
Nov 3, 2009 09:25 PM
Yorkie Mama
Apr 7, 2008 11:33 AM
