need help
Old Mar 22, 2014 | 10:40 PM
mikerp76's Avatar
need help
on my 67 valiant slant 6 i have a tube that sits in the intake under the carb. i'm not sure what it is for but mine had a melt down last week and i have been trying to find this part or some way to plug the hole in the intake. soes anyone here have any ideas.
Old Mar 22, 2014 | 11:55 PM
John Van's Avatar
sounds like the stove pipe, check this link:http://www.slantsix.org/articles/man...s-mounting.htm
good luck,john
Old Mar 23, 2014 | 02:57 AM
Make sure you have the proper concave washers for the exhaust
Old Mar 23, 2014 | 07:31 AM
pro-tech's Avatar
ics:If you have pictures it would at least let us know what you are talking about...Bill
Old Mar 23, 2014 | 08:08 AM
mikerp76's Avatar
i will have to take some pics next week when i go out to where my car is. it looks like a stainless bolt that screws into the intake floor under the carb. between the intake and exhaust manifold.
Old Jun 12, 2014 | 08:40 PM
mikerp76's Avatar
tried to up load some pics from my phone but for some reason i couldn't. but i did come up with a solution. i am using a bolt that is the same size as the threads and a couple of washers and a nut. screw the bolt into the intake with a washer then install another washer on the bottom with the nut then tack the nut into place.
Old Jun 13, 2014 | 05:54 AM
pro-tech's Avatar
Are you sure it is a 67 engine I seem to remember that pipe under the newer engines and it was part of the EGR system and 67 didn't have EGR...Bill
Old Jun 13, 2014 | 06:41 AM
mikerp76's Avatar
the engine was replaced before i got the car. not sure what year it is.
Rumblefish318
Jun 30, 2013 12:56 PM
73plymduster
Aug 15, 2010 10:21 AM
