need help
need help
on my 67 valiant slant 6 i have a tube that sits in the intake under the carb. i'm not sure what it is for but mine had a melt down last week and i have been trying to find this part or some way to plug the hole in the intake. soes anyone here have any ideas.
sounds like the stove pipe, check this link:http://www.slantsix.org/articles/man...s-mounting.htm
good luck,john
good luck,john
i will have to take some pics next week when i go out to where my car is. it looks like a stainless bolt that screws into the intake floor under the carb. between the intake and exhaust manifold.
tried to up load some pics from my phone but for some reason i couldn't. but i did come up with a solution. i am using a bolt that is the same size as the threads and a couple of washers and a nut. screw the bolt into the intake with a washer then install another washer on the bottom with the nut then tack the nut into place.
Rumblefish318
Jun 30, 2013 12:56 PM
ics:If you have pictures it would at least let us know what you are talking about...Bill
