Need help with a Holley 1945
Old Aug 18, 2012 | 06:29 PM
cmetzbower's Avatar
I have a 84' Dodge D100 with a 1BBL Holley 1945 that I've been having problems with but I've finally figured out part of the problem. When I opened up the carb I found the edge of the rubber pump cup had sheared off and was loose in the bowl. I also found allot of what looks like carbon in the bowl and through out the carb. So my question is where is the carbon coming from and how can I fix the problem? Thanks.
Old Aug 19, 2012 | 10:45 AM
70newport's Avatar
from my understanding ( NOT AN EXPERT AT ALL) carbon is going to acumulate no matter what to some extent but the carb not being adjusted properly and bad fuel are a couple things that can contribute to this. Or that is what I have found from my readings. My 4150 does a similar thing and i have to clean it out every couple summers. this year it seems to be doing a bit better after having some help tuning it.
Old Aug 19, 2012 | 04:09 PM
Gorts 5th's Avatar
Smile
sound s like u need a rebuild not a big deal your local parts store should be able to help
i use to have to spray down my holly also for carbon use to plug the air bleeds
SCPerf
Feb 13, 2016 11:41 AM
B055
Mar 21, 2015 06:14 AM
Robert Weaver
Sep 27, 2014 07:07 AM
cmetzbower
Oct 1, 2012 03:44 PM
scott2683
Mar 11, 2011 01:16 PM
