New cam?
Old Aug 28, 2013 | 02:09 PM
mrzods13's Avatar
New cam?
Ok so I want to upgrade my 68 newport from a 2bbl to 4bbl. Jegs has all of the necessary brackets for the 4bbl, my question is do I need to put a different cam and lifters in it before upgrading, want to make sure the information I received is correct or incorrect, nothing crazy just a 600 cfm edlebrock with the 2186 performer intake just want to make sure it is necessary before buying the new cam and lifters and double roller timing chain.
Old Aug 28, 2013 | 02:35 PM
A new timing chain certainly would not hurt. The cam and lifters do not have to be changed Why convert without taking advantage of installing a mild cam
Old Aug 28, 2013 | 03:29 PM
moe7404's Avatar
first figure out the what you will be doing with it. 1. full out racer. 2. street racer. 3. local cruiser. 4 long distance cruiser. 5. full show car. dont forget the wilder the cam and carb , rear end, the less streetable it will be.
Old Aug 29, 2013 | 12:38 AM
mrzods13's Avatar
Mainly just a local cruiser nothing crazy leaning towards a mild cam.
Old Aug 29, 2013 | 12:54 AM
mrzods13's Avatar
What would be a good mild cam to buy I am looking at the comp cam kits that come with lifters cam and double roller. What kind of lift should I be aimng for want something that can be used with the stock convertor.
Old Aug 29, 2013 | 03:26 PM
PK1's Avatar
PK1
More info we can help you get dialed in:
Engine:
Trans:
Rear end:
Tire OD:
If Auto stall speed:
AC and or Power Brake:
1968GTX
31
Feb 19, 2014 10:00 AM
440 aspen
Aug 8, 2013 08:20 PM
1923tbucket
Apr 3, 2013 02:15 PM
67hemidart
Apr 26, 2012 07:18 PM
freds65300l
Mar 10, 2012 04:40 PM
