Oil pan 440
Old Sep 11, 2012 | 09:03 AM
440's Avatar
440
Oil pan 440
I have a 440 in a street rod. Motor came from 77 Ramcharger with 6qt rear sump pan. These pans are becoming increasingly rare to find. My question is: since I don't have a crossmember under the engine, can I install a mid or forward pan with appropriate oil pickup without problem? Are the windage trays specific to fwd, mid, or rear pans? Is the threaded hole that the pickup screws into in the same location on all 440's?
I only have 3 inch clearance from pan to street and it's easy to ding them.
Old Sep 11, 2012 | 08:29 PM
mopar4ever's Avatar
I would probably recomend a center sump pan with the correct pickup.Most pans come with a welded in windage tray if your not looking for a lot of capacity. (5-6 Quarts ) Summit, jegs or ebay has what you need. Greg
Old Sep 12, 2012 | 08:40 AM
The threaded oil pickup hole is in the same place on all 440's. Windage trays are the same because of the before mentioned. And yes you can put a forward or middle sump pan on. I prefer the middle sump or car sump.
Old Sep 13, 2012 | 07:59 AM
440's Avatar
440
Thanks for the help. I feel a lot better knowing I have other options with regards to the oil pan and windage tray.
MarkyMark12345
Apr 10, 2009 06:43 PM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
