oiling holes in distribution cover doubt...
Old 02-21-2012, 02:43 PM
bugy's Avatar
Question oiling holes in distribution cover doubt...
hello guys, im rebuilding a 360 LA, there are 2 holes which go from lifters oiling through cam plate where distribution cover goes, i just want to know if they are blocked from factory or they are just blocked with the cam plate... cam plate is blocking it anyway, but just want to be sure, are they factory blocked with something or they're coming unblocked? thanks guys.
Old 02-21-2012, 03:08 PM
Steel drive in plugs should be in there.
Old 02-21-2012, 03:12 PM
bugy's Avatar
so, those are coming blocked with plugs from factory?
Old 02-21-2012, 05:58 PM
Yes, and they are threaded in, at the back of the block.
Old 02-22-2012, 01:49 PM
Looked at a 1970 318 block I have and it is plate only, one other (year?) has plugs under the plate. A Mag block I have has plugs and a groove in the plate, for what reason I don't know. Go figure. I don't think it's a big deal aslong as the plate is flat with no groove.
Old 02-22-2012, 02:27 PM
bugy's Avatar
thank you there, im using threaded plugs just in case, good advicing there!
hckrphil
05-11-2014 06:45 AM
Kevin71
07-11-2013 07:43 AM
koterkid
05-26-2013 09:49 AM
bugy
02-21-2012 09:39 PM
Jaykeane
06-01-2011 06:13 PM
Quick Reply: oiling holes in distribution cover doubt...
