Performance Cam
Performance Cam
Hi everyone
I have a 2012 Charger RT. I have started doing modifications as I am getting more into going to the drag strip. I have been looking at performance cams and just wanted anyone's input or opinion on the Mopar Performance Purple Shaft Camshaft - P4529315AE just looking for input if I should consider this cam shaft or go with a comp cam
Thanks in advance for any input
Here are some suppliers for the gen 3 do you have headers and a cat back?
http://www.shophemi.com/c-1320-hemi-...nce-parts.aspx
https://www.highhorseperformance.com/Default.asp
Hi everyone
You should look at a block off kit for the MDS and replacing the MDS lifters with any Gen 3 cam change/upgrade.
Thanks gang
If you're getting serious about the dragstrip (meaning, serious about spending money), you might want to upgrade your cylinder heads and valve train along with your new cam.
There are some great all-in-one cylinder head and valve train kits on shophemi.com and similar sites. If you're having a shop do the installation, talk to them about your plans and goals so they can help you order parts (or just do it for you). Just be warned, you can spend a lot of money on this stuff really fast!
THEhomelessONE
Dec 26, 2016 10:08 AM
