Piston Question
Old Feb 27, 2013 | 08:24 PM
raycan2's Avatar
Piston Question
What does a KB 237 mean on the pistons, I took the 440 apart and took the block in to get boiled and I was looking at the pistons and it said on the side KB 237
Old Feb 27, 2013 | 09:04 PM
That is the model # of the piston !! Keith Black 237
Old Feb 28, 2013 | 07:20 AM
raycan2's Avatar
TVLynn I striped down the motor to the block and and took it to a place where they are gonna boil it and clean as well as the heads pistons and ect. Being that I did not know anything about the car when I bought it or the motor what information do I need to get from the machine shop where its at the will be help full, They can measure anything they told me.
Old Feb 28, 2013 | 06:15 PM
Garys69RR's Avatar
Go to the Keith Black web site and there you will find all the specs on the KB 237 piston. If you are re using those pistons, start by determining what you want your final C/Ratio to be, and work from there.
Old Feb 28, 2013 | 06:42 PM
Also they should be stamped STD .020 .030 depending on size The machinist will tell you what size parts to get
Old Mar 1, 2013 | 03:47 AM
Garys69RR's Avatar
I looked on the KB website, and that piston has a Compression Height of 2.067 inches. Which means that on a block that is at factory specs, the piston will be .015 inch below deck. That is good for quench and squish, but you need to watch your C/R.
Cracocuda
Dec 24, 2009 04:18 PM
deadkelly
Nov 20, 2009 03:21 PM
scotts74birds
Nov 19, 2009 01:49 PM
Fireball57
Oct 10, 2009 03:27 PM
sirus444
May 27, 2009 09:53 AM
