pressure buildup in tank, leads to fuel leak.. HELP!
Old Jul 29, 2012 | 05:33 PM
Younggun's Avatar
Question pressure buildup in tank, leads to fuel leak.. HELP!
i have an 88 d150 4barrel. was driving it for a few miles and someone at the light told me i was leaking something...... turns out to be fuel (as if the gas mileage isnt bad enough ha). got it home and there was a steady stream coming from underneath. i cracked the gas cap and there was alot of pressure built up. leak stopped after that. anyone had this problem? solutions? thanks in advance
Old Jul 29, 2012 | 07:14 PM
mikerp76's Avatar
try getting a vented fuel cap. and also try to find the source of the leak.
Old Jul 30, 2012 | 02:36 AM
X2
There should be a vent tube on the tank to prevent that from happening or an EVAP system that collects the gas vapors and purges them into the motor during cold startups. Either way, the vent system is clogged and you need to unclog it. You also need to find the leak and get that fixed.
northcoasttip
Oct 5, 2011 06:30 PM
Archelon99
Oct 1, 2011 09:59 PM
Rene J Grode
Aug 1, 2011 08:06 PM
Omicron
Nov 29, 2009 11:54 PM
MuscleCrazy
Mar 3, 2009 04:25 PM
