Recommend me a carb for 1979 Cordoba
Old Jun 6, 2013 | 12:10 AM
TurboDouche's Avatar
I'm looking for a 2bbl replacement carb for my Cordoba that I can use with the stock intake. I'm trying to get away from the whole lean burn situation.
I know the best thing to do would be to scrap the original carb and intake and go with an Edelbrock Performer setup, but I really don't want to invest that much money if at all possible.
Any recommendations?
Old Jun 6, 2013 | 07:19 AM
Holley offers new two barrel carbs.
Old Jun 6, 2013 | 10:54 AM
pro-tech's Avatar
I have a Holley 2 barrel factory carb off a 78 360 D150 If its some thing you could use. ( No lean burn)
Old Jun 30, 2013 | 08:38 PM
Zoomer59's Avatar
Dump all the lean burn stuff
a good aluminum intake and a 600 cfm carb is the way to go.even a old late 1960s cast iron 4bbl intake will work.and throw that lean burn distributizer away too.
Old Jun 30, 2013 | 08:47 PM
It should run ok without the lean burn. You need to install a conventional ign. Distributor, ign module & ballast resistor Probably $50 at the local Pick a Part
from any 318/360 70-80? car,truck,van Or might find a set on ebay
Here is a cheap option
http://www.ebay.com/itm/Small-Block-...cedf44&vxp=mtr
Old Jul 7, 2013 | 12:20 PM
ColtDiesel2013's Avatar
Question
Does the 79 Cordoba come stock with a 2bbl carb? I was told that mine had a 4bbl. (this is going to be my first project so I really don't know). electric carb right?
Old Jul 7, 2013 | 12:28 PM
I don't know if they all did, buy mine came stock with a 2bbl.
Old Jul 11, 2013 | 09:49 PM
still got the cordoba? what have you replaced if anything?
Old May 19, 2015 | 02:05 AM
I had the carb rebuilt and bought the distributor mentioned earlier. I also had to get a new coil and plug wires. Runs real nice.
Old May 19, 2015 | 03:30 PM
Was a problem since new.. The conversion was done a lot by the factory !!! They had to get approval from the EPA to do so, but they had so many drivability complaints
TurboDouche
Jun 24, 2013 09:17 AM
'79Cordoba
Feb 15, 2013 10:49 AM
MAGNUM GT XS22L9R
Mar 29, 2011 02:54 AM
MAGNUM GT XS22L9R
Mar 25, 2011 04:38 PM
nesparky
Jun 20, 2009 12:17 AM
