Rocker are assembly
Old Dec 28, 2013 | 10:25 AM
newto440's Avatar
Rocker are assembly
Which way do the holes in the rocker arm shaft point up or down (for oiling the rocker)? Thanks. This is in a 1977 440.
Old Dec 28, 2013 | 11:59 AM
Holes Down toward the head !!!!
Old Dec 28, 2013 | 03:10 PM
moe7404's Avatar
mount those rocker shafts with the bottom holes 15 degrees toward the out side, I.E. the valves. from factory service manual. tighten rocker shaft bolts to 25 ft-lbs.. valve cover bolts to 40 INCH lbs. on the exhaust manifold nut to 30 ft lbs. DO use anti-seize compound on bolts on exhaust nuts. and ALL bolts on the bottom of truck. take to 60-70 % of full ft lbs first time, after 5-7 full heat cycles take to full torque, if it leeks before that take to full torque.
76NY440_nTX
Aug 12, 2010 08:52 PM
HEMI-ITIS
Jul 5, 2010 11:41 AM
jobberone
Sep 3, 2009 09:34 AM
66dartvert
Apr 14, 2009 06:23 PM
rsmith
May 30, 2007 05:54 PM
