Vacuum
Old Dec 29, 2013 | 07:32 AM
Dave E's Avatar
Vacuum
guys I need some help with Vacuum... I am swapping a 98 magnum 360 into my 86 W250. Putting an edlebrock carb and intake on the magnum. Now I am doing away with the vacuum controlled axle engagement system and replacing with a cable. Sooo... What should that leave? What will need manifold vacuum and what will need the metered vacuum off the carb? This is a bare bones truck with no frills only heat. I am going with the stock distributor from the truck... That is all the information I can think of. Any help would be appreciated. Also the intake is a non EGR intake.
Old Dec 29, 2013 | 07:44 AM
Brake booster
Dist advance
Vacuum pod under dash? unless it is cable operated in 89!
About all i can think of....
But like you said... Swap out the Transfer case with a cable set up and change the front hubs to Manuel locks.
Old Dec 29, 2013 | 07:50 AM
Dave E's Avatar
Brake booster
Dist advance
This is what I am doing for the 4x4...
http://www.summitracing.com/parts/po...dge/model/w250
I am very glad I found this little gem... Removes the old vacuum switch on the D44 housing with a cable actuated unit. I should just have to block off the vacuum ports on the transfer case to keep it sealed tight. This will also allow me to run 2 wheel drive low... which is kinda pointless but cool none the less.
Brake booster will be straight manifold... and distributor will be metered correct? I think the 86 is all cable under the dash. I believe when I remove the old 86 360 I will document all the vacuum I can and just try to filter through all the unnecessary stuff.
Old Dec 29, 2013 | 08:28 AM
Sounds and looks like a good plan to me...
Post lots of pictures...
66coronetgirlie
Aug 9, 2010 10:41 PM
340CUDA
Mar 16, 2009 05:27 PM
Commando
Sep 23, 2008 07:35 AM
gotdust
Aug 10, 2008 12:14 PM
burnsy26
Oct 1, 2007 01:35 PM
