Shorty Spark Plugs - Mopar 440
Old May 22, 2014 | 08:13 AM
hckrphil's Avatar
Hey Everyone,
Car is just about ready to fire up FINALLY.... As I'm putting in the spark plugs, its EXTREMELY tight.
What would you recommend for some sort of "shorty" spark plug to go with my Edlebrock Aluminum heads?
I heard Autolite AR74's...... but those are hard to find..... other suggestions?
Motor has the Edlebrock heads, cam... completely refreshed.
~Phil
Old May 22, 2014 | 08:37 AM
Check Accel for a cross for the plug in a shorty....
Old May 22, 2014 | 01:53 PM
moe7404's Avatar
i checked and it is the same heat range as a champ J12YC. which is VERY hot heat range for a high performance engine. course i dont like champion plugs. NGK makes good plugs. but most of the time if you drive hard, and have a high performance engine, its best to get a plug that is 1 to 2 heat ranges colder than stock. the stock heat range is for aunt May in the winter.
Old May 22, 2014 | 03:31 PM
Archer's Avatar
Phil -
Been using the Accel "shorties" or peanut plugs for the last five years.
Work as well as any other plug, and does help the header clearance.
Old May 22, 2014 | 04:12 PM
Accel 0416s-4 will do the trick..
austin
Sep 18, 2012 12:37 PM
deadkelly
Aug 26, 2011 02:06 PM
moparsforlife
Sep 2, 2009 04:47 PM
eby94
Feb 23, 2009 08:07 AM
Commando
Feb 4, 2009 09:22 PM
