Smoking engine
Old Nov 4, 2012 | 08:47 AM
Shrug's Avatar
Smoking engine
OK, I just picked up a 66 Dart wagon with a Magnum 5.2L from a 96 Dodge Ram.
Once the car warms up if I do anything but accelerate really gently, it blows smoke. I drove the car home 20 miles on the freeway and I was billowing smoke like crazy. Does not seem to smoke when idling.
So any ideas? Valves or rings?
Thanks!
Old Nov 4, 2012 | 08:56 AM
Garys69RR's Avatar
Check your PCV valve and valve covers. Also I have seen a motor so sludged up that the oil drain back holes were plugged. Trapped oil in the valve covers, filled them up! Then oil was sucked in the valve guides. No more smoke after I un plugged the holes.
Old Nov 4, 2012 | 01:16 PM
blue 68 gts's Avatar
What colour smoke?
White = coolant
- Cracked head / block
- Blown head
- Ect
Blue = oil
- Rings
- Valve guide seals
- Ect
Black = fuel
- Excessively running rich
- Running rich
- Rich
Old Nov 4, 2012 | 03:13 PM
Shrug's Avatar
Oh it is blue. It is most assuredly blowing oil!
Old Nov 4, 2012 | 05:54 PM
Chryco Psycho's Avatar
Compression test , wet & dry , if it changes with a wet test the rings are bad , if it is smoking under decel probably bad valve guides
Old Nov 4, 2012 | 06:10 PM
Militiaof1's Avatar
I'm going with rings on this, but as we all know ics:. Sounds like a cool ride.
Old Nov 4, 2012 | 07:38 PM
Shrug's Avatar
OK now I am confused. I can never see the smoke clearly myself because all my windows are limo black. I had my neighbor come over (another car guy) he swears the smoke is white. Maybe it is :/
Maybe it is just head gaskets? Sigh, I guess I have to pull the heads and have a look.
I wish I could get a few more opinions locally.
I miss all my friends back in LA. One phone call and I would have a half dozen friends over to help. I am all alone here in Phoenix
Old Nov 4, 2012 | 07:47 PM
Shrug's Avatar
You can see pics here http://www.facebook.com/media/set/?s...3811004&type=3
Old Nov 4, 2012 | 08:32 PM
Has the intake been changed ??? Could have used the wrong intake gaskets. Could be a bad bottom cover on the intake - sucking air through the PVC valve
Old Nov 5, 2012 | 09:09 AM
Shrug's Avatar
I really am mentally challenged sometimes!
I never actually pulled the plugs.
I took out all the passenger side plugs, three had normal carbon wear, one looked pretty darn clean.
I started the car up and my pop put his hand up to the passenger side exhaust, it came away wet!
Arrghh! Just need some darn head gaskets.
Old Nov 5, 2012 | 03:56 PM
Shrug's Avatar
I am so mentally challenged!
Take a look at the pic.
Old Nov 5, 2012 | 05:51 PM
Gorts 5th's Avatar
Smile
8 is defiantly burning oil 2 somewhat burning oil looks like valve seals are in need of replacing
or your pcv is not working start with the cheapest fix first
Old Nov 6, 2012 | 06:19 PM
Garys69RR's Avatar
Before you pull the heads, have a shop do a pressure check on the cooling system. And are you losing coolant? That would be a sign.
dchamp
Dec 23, 2013 09:01 AM
rexus31
Oct 11, 2009 10:07 AM
dchamp
Jan 31, 2009 08:05 PM
eustainslee
Nov 5, 2008 03:12 AM
sheridan
Nov 1, 2008 07:40 AM
