which spark plugs?
Old May 9, 2011 | 01:03 PM
mopar777's Avatar
which spark plugs?
I am currently using autolite 85's in my 440. Pretty mild build, race ported 906 heads
any suggestion for better plugs?? Looking for the good and bad sides
Old May 10, 2011 | 02:48 AM
I have noticed that Champion plugs have always worked best in my mopars. I have heard about other brands skipping and misfiring for unknown reasons.
Old May 10, 2011 | 02:22 PM
I use Champion.
Old May 10, 2011 | 10:34 PM
Silverick's Avatar
Champions in a Mopar.
Can't give you a reason why, it's just the way it has always been.
Old May 13, 2011 | 07:41 AM
bboogieart's Avatar
I am glad and surprised to see this, as usually the expensive plugs are advised, NGK or Bosch. I also, have always used Champion as this is what Chrylser used and the racers of the day all ran champion in mopars. I usually go with the Firestone tires as well for the same reason.
Old May 15, 2011 | 03:04 PM
mopar777's Avatar
re:
good stuff guys.
looks like champions next time.
Old May 15, 2011 | 05:11 PM
Archer's Avatar
777 -
General consensus in these parts are autolites. I've used Accel in thr past have have gone back to their shortie plugs due to a lack a header clearance. In all honestly, not sure I've seen all that much of a difference. However, the shorties or "peanut" plugs do give better clearance and that means fewer burnt wires.
Old May 15, 2011 | 06:30 PM
John Van's Avatar
I hate changing plugs in my 440 cuda, I have found that the AC's R43s work the best for me.
Old May 22, 2011 | 10:04 PM
Kevin74's Avatar
I use auto lite in my 318 seems to work well with it, seems most like the champians here but i cant seem to have any luck with them, they dont seem to last long where autolites i can use for a long time. maybe cause its a small block and i imagine you- all have big blocks? I set gap at just a slight bit over 0.40, thats what they were set at when i bought the car.
Old May 23, 2011 | 01:40 PM
.040 is a bit much, stick with .035 if you have a stock/elect ign. Now if you have a MSD things are different.. I have always used Autolite plugs
Old Dec 4, 2014 | 02:20 PM
Atlas's Avatar
Can't say what works best in Mopar's but champion in Harleys are the worst. Used to DYNO hotrod Harleys every month thru the 90's and had a lot of tracking with them. Autolites always worked best.
austin
Sep 18, 2012 12:37 PM
deadkelly
Aug 26, 2011 02:06 PM
moparsforlife
Sep 2, 2009 04:47 PM
eby94
Feb 23, 2009 08:07 AM
Commando
Feb 4, 2009 09:22 PM
