Vacuum leak through carburetor secondaries?
Old Dec 13, 2014 | 10:50 PM
  #31
That is not a mopar carb so you will definately need the adapter.. Maybe cut the lever down...
Old Dec 14, 2014 | 04:38 PM
  #32
Also Try a couple of other things at the moment.....
Plug the PCV port at the carb.....
Also Plug the The Brake Booster at the Intake for now...
See if that helps......
Old Dec 14, 2014 | 04:49 PM
  #33
If that dose not help...And providing there are no vacuum leaks.. I'm going to have to say that. It is my understanding that the cam to crank timing is not set up correctly... That would be next on my list of things to go in and look at... Sorry....
Old Dec 15, 2014 | 07:07 AM
  #34
josehf34's Avatar
The brake booster and the PCV valve has been always plugged like you recommended, I think there's nothing more to check so it's time to remove the heads. I have a couple questions about this procedure because I've never done this completely by myself.
Where can I find the torque specs for this heads?
Which recommendations should I take in count while removing the heads and putting back on?
Is there a torque wrench plug set that will you recommend for this procedure (heads removal, crank pulley removal, etc) ?
Old Dec 15, 2014 | 11:18 AM
  #35
I think you should check the cam to crank timing alignment first....
Are you sure you are up for that task? This might be a task for someone with a little more experience. (No Offence)
1-You will need a good Service Manuel.... Like a Motors Manuel.... To get the specs you need.
2-Not sure what your getting at?
3-That would be Auto 101...
Way to in-depth... Sorry
Old Dec 15, 2014 | 08:20 PM
  #36
josehf34's Avatar
Don't worry, any recommendation will be welcome, but to be honest with you, I want to do the job by myself for learning purposes and because I've more time and patience than my mechanic so the ending results will be better.
I've previously done some work with friends on chevy 327 and 350 but never on mopars but I think will not be much difference (or I hope so...)
What about this book? http://www.amazon.es/Rebuild-Small-B.../dp/1613250584
If I remove the radiator, fan hose and pulleys, do you think I'll be able to check the cam timing alignment without pulling the engine out the car?
Old Dec 16, 2014 | 06:05 AM
  #37
I have that book myself.... Its a good book....
Yes... Just pulling the front apart will get you there so you can check that.
Dave E
13
Nov 1, 2015 09:46 AM
jj123
Jun 5, 2014 02:29 AM
Darryl Schlegel
Apr 8, 2011 12:46 AM
66coronetgirlie
Aug 9, 2010 10:41 PM
340CUDA
Mar 16, 2009 05:27 PM
