Valves or rings
Old Nov 24, 2012 | 07:40 PM
Shrug's Avatar
Valves or rings
Hey all, short of tearing the engine apart, is there any way to tell if I am smoking because of rings or valves?
Thanks!
Old Nov 24, 2012 | 08:00 PM
PK1's Avatar
PK1
Compression test to find the offending cylinder or cylinders. When or if found use a squirt of oil into spark plug hole and retest. In most cases the oil will seal the rings briefly and bring up the reading.
Note: Carb blades open to get air in, all plugs out, fuel shut off, no spark. Have battery in good shape or car orientated in good spot for jump or leads.
Old Nov 24, 2012 | 10:00 PM
78doubleR's Avatar
also cylinder leak down test if the compression test checks out fine.
Old Nov 25, 2012 | 05:20 AM
Try compressed air in the spark plug hole with adapter, both valves closed at TDC. If you here air sounds at carb = Intake valve, at exhaust = Exhaust valve, at valve cover breather or dipstick tube = Rings.
Old Nov 25, 2012 | 09:22 PM
When does it smoke ?
Old Nov 26, 2012 | 07:20 AM
Shrug's Avatar
I will try this first.
Old Nov 26, 2012 | 07:21 AM
Shrug's Avatar
How do I do this, please?
Old Nov 26, 2012 | 07:26 AM
Shrug's Avatar
To get compressed air in the cylinder, is there some kind of adapter I can get for my air hose?
The engine smokes really heavy when I rev it up.
I do not want to go through the trouble of swapping out my heads, and then end up having to pull the whole motor anyway.
Old Nov 26, 2012 | 07:33 AM
Gorts 5th's Avatar
Smile
how many miles on the motor?
what color smoke white blue black?
you may need valve seals if your lucky.
cudaracer
Jan 7, 2020 12:50 PM
Elvin
May 26, 2011 02:37 AM
RXDawg
Feb 15, 2009 08:02 PM
deadkelly
Dec 30, 2008 05:58 AM
pinky
Mar 31, 2008 07:30 PM
