Welding advice
Old Sep 22, 2013 | 12:52 PM
Dave E's Avatar
Welding advice
Any old hand welders have advice for a rookie? I made my first attempt at my own exhaust and it looks pretty terrble. I have learned that exhaust is nothing like sticking two pieces of metal together for structural welding. I kept burning straight through the pipe leaving big holes. Hobart Handler 140 rig had my voltage on 1 and wire speed on 30. Help ?
Old Sep 22, 2013 | 01:00 PM
All I can Say is ........... Practice makes perfect.... I'm not a welder...
But I do Weld......
Old Sep 22, 2013 | 01:51 PM
pro-tech's Avatar
Like Bob said practice, but for starters if you are burning through on the lowest setting you need to increase your wire speed. Is it flux core wire or gas shield mig? If it is gas shield you can increase the flow of the argon/co2.. to help cool the weld..If that is still to hot you will have to weld short bursts and let them cool. Basicly just be trigger happy on /off and fill the gap/hole...Is this new pipe or old rusty pipe? with a wire feed welder the metal needs to be clean,. free of rust...Bill
Old Sep 22, 2013 | 02:05 PM
slade's Avatar
everything bill said. you can weld it in section also like a body panel. use a weave pattern alsp
mostly take your time. im no expert welder but a do dabble when i get the chance
Old Sep 22, 2013 | 02:39 PM
Dave E's Avatar
I haven't upgraded to the gas setup yet. I am still using flux core. It is old rusty pipe but I did a thorough job of cleaning up each side of the parts I was to be welding. I actually decreased the wire speed thinking I was "pushing" through... So I need to increase wire speed and fill in the space as I am burning? Thanks for all the input guys. I know practice is the best method but I want to make sure I am practicing good procedures not just wasting wire and metal.
Old Sep 22, 2013 | 02:43 PM
slade's Avatar
slow wire burns hotter
Old Sep 22, 2013 | 05:35 PM
PK1's Avatar
PK1
You want to make small 1/4 to 1/2 inch stitch welds leaving a 1/2 inch of un -welded space between wleds as you walk around the diameter of the pipe. This will insure you are starting on cool metal and not having you chasing heat settings.
Slightly bevel the outside edge of both pipes by running a grinder at a 45 degree angle along the to be welded surface. Almost like sharpening it. But just make a pass to knock off contaminates.
Old Sep 22, 2013 | 08:23 PM
Drag Pak's Avatar
Use some 0.025 wire. You will see a world of difference!
Old Sep 22, 2013 | 08:32 PM
Dave E's Avatar
Is this recommendation for thin welding jobs in general or steel pipe/exhaust in particular? So much to LEARN!!!
Old Sep 22, 2013 | 08:48 PM
Do yourself a huge huge favor. Buy whatever it takes to upgrade the machine to gas, and if it cannot be, sell it and buy one that "is" (gas) even a used (brand name) machine.
I don't even bother to use "fancy gas" on my two MIGs, I use straight CO2 which is a heck of a lot cheaper. It's a little more on splatter, otherwise works fine
Last, welding used rusty thing exhaust, full of junk and carbon, CAN be a little difficult. New pipe--not so much.
As above it takes practice, use short beads, and if possible, rustle up some scrap that you can practice on in a good position where you can concentrate on learning how.
Old Sep 22, 2013 | 08:58 PM
Dave E's Avatar
Fortunately all I need is the tank... This welder came as a kit (gas ready) just buy your own expensive *** tank and viola! Any recommendations on tank size for a guy who fires up his welder maybe once a month?
Old Sep 22, 2013 | 09:11 PM
Dave E's Avatar
Found this helpful
I found this very helpful on Miller's website. Very direct and written in a "welding for dummies" kind of way. Thanks for all the tips and advice guys. Hopefully this thread will help others as well!
http://www.millerwelds.com/resources...tips/index.php
Old Sep 23, 2013 | 03:49 AM
If you have any welding shops around you, give them a call and as if they offer day or two day classes on basic welding. You can pick up so much from people who weld for a living.
I'm no welder, and I'll go months between laying a bead. Before that happens, I'll grab some scrap metal close to what I'll be welding and get some practice beads in first.
dgbcharger
13
Dec 27, 2013 08:24 PM
dgbcharger
Jul 2, 2013 03:47 PM
Newf Wit a 440
Nov 22, 2011 05:07 AM
idahoprime
Aug 19, 2010 05:03 AM
Crazy4Carz.Com
May 21, 2009 06:24 PM
