wont fire
Old Jul 13, 2012 | 05:52 PM
lifted150's Avatar
wont fire
OK so i went to fire my 85 w150 up to day an all she did was turn over, i she did not even try to fire, so i jump out check to see if i'm getting fuel I'm good there, i pull a plug wire from the dist to see if i'm getting spark an nope no spark.. so i then pull the coil wire off to see if i'm getting spark from that i'm getting some, the coil is a almost new flamethrower brand coil. so i replaced the coil wire, nothing, i pulled the dist cap, the cap looked pretty clean but replaced the rotor as it looked a little worn but not bad, but still nothing?? do you guys have any tips or idea's?? i don't want to run out an buy a new dist for 80.00 lol when it could be something else mabe?? hahaha no info would be great guys
Old Jul 13, 2012 | 08:26 PM
Take your distributor out. Put your voltmeter on millivolts. Connect the leads to the distributor and turn it. You should generate some millivolts. If you don't get a reading your pickup coil is probably toast.
Old Jul 16, 2012 | 12:20 AM
lifted150's Avatar
well i put a new starter solenoid switch, i think that's what its called, on it an she fired right up??? that should have no effect on spark should it?? it makes no sense, i am thinking maybe a bad key switch?? but ya after i put that SRS on she fired right up first turn of the key usually it takes a few cranks..
Justin Ward
Sep 3, 2021 10:38 AM
MReeves
Jan 3, 2011 04:14 AM
Valcam
Jan 31, 2010 11:59 AM
chavlics
May 29, 2009 02:36 AM
wht96
Mar 31, 2008 11:21 PM
