1950 Plymouth Transmission Linkage
Old Jun 5, 2018 | 06:06 PM
Guillermo Durgin's Avatar
Hello Mopar owners, I have a 1948 Plymouth Deluxe, 2 door sedan. But the engine is from a '49 Plymouth; I had to change the transmission and purchased a 3 speed transmission from a '50 Plymouth, which I recently installed with a new clutch and pressure plate. However, after I started it it seems to be stuck in 2nd or 3rd gear. I would appreciate any photos of correctly adjusting the transmission linkage rods on each shifter lever on the transmission, and which lever works for the gears. I believe reverse and 1st are on the same lever, with 2nd and 3rd on the other after moving the lever that engages the ball action, but am not sure. Assistance (and photos) is greatly appreciated.
G Durgin
Oakland, CA
Old Jun 5, 2018 | 07:56 PM
So what you are saying is ????????? You have a Hy-Drive and don't know how to adjust it??????
Old Jun 7, 2018 | 05:32 PM
hkestes's Avatar
Try this Trouble Shooting Guide
http://p15-d24.com/files/file/124-tr...ansmissionpdf/
Old Oct 15, 2019 | 03:09 PM
gdfinley55@yahoo.com's Avatar
G Durgin
Oakland, CA
Old Oct 15, 2019 | 03:19 PM
I have the same problem
I have a 1950 Plymouth that won’t go into reverse of 1st gear. I used a 1949 dodge pickup 218 motor. I had to change the front motor mount pedestal and bell housing the truck bell housing has the pedals and master cylinder integrated in the housing. The then changed the starter because trucks were still floor start and then the filter housing. Now the reverse lever hits the starter. I looked at a original 3 Speed Plymouth and the lever has plenty of clearance could they have sent me the wrong bell housing?
73Monaco
Apr 27, 2021 11:28 AM
smoot
Jun 10, 2016 05:58 PM
demetri
Apr 22, 2014 02:28 PM
MilesP
Feb 26, 2012 07:19 PM
luke
Jan 3, 2011 08:17 PM
