1986 727trans leaking lots fluid
Old Feb 10, 2020 | 06:59 PM
360 mafia's Avatar
my 1986 ram charger 4wd tranny leaks badly.Leaked 1 month after purchase.Installed new turque converter seal.Not the problem.So replaced pump with new nos ,converter, and installed a rebuild kit,but did not mess with the valve body.Also installed a new 3 row radiator[had all the parts in my warehouse already to go]Will add from day 1,the tranny took a long time to shift thru the gears till it reached temp.Then it ran great all day.That never changed even after I installed a rebuild kit in it.Fluid had great color til the day it poured out all over my driveway.It was almost black.It was never in 4 wd during this time.The owner had differential rebuilt by a pro,but he rebuilt the tranny[found all the receipts].Any suggestions?
Old Feb 10, 2020 | 08:57 PM
Did you ever ajust the bands?
Or check the seals at the shift linkage or pan gasket?
Old Feb 11, 2020 | 02:28 PM
360 mafia's Avatar
checked all 3 or those things.Especially the seal around the shift linkage.That was leaking the day I bought it.1st item I replaced on tranny
Old Feb 12, 2020 | 07:25 PM
Pick up this book....
Amazon Amazon
Buy a good Overhaul kit from Red and Arts / Cope Trans / A&A trans / read the book pick up a few tools and do it yourself....
Keep us posted.. You will do just fine... Read the book twice before starting...
Old Feb 14, 2020 | 06:20 PM
360 mafia's Avatar
Just got the rebuild kit.Going to replace the valve body to the original spec.Of cource its now raining everyday when its not freezing cold every day.thanks
Old Feb 15, 2020 | 06:58 AM
Make sure you take it apart and clean it also... Dont forget to use the rite lube putting it all back together. and be careful not to rip or roll over and of the seals.
Cheers
Roosevelt1940
Nov 25, 2017 07:14 PM
mutboy
Sep 26, 2015 01:03 PM
bigred4691
Apr 16, 2011 10:50 PM
scott2683
Apr 5, 2011 09:37 AM
ProEmaster
Feb 11, 2008 11:23 AM
