2004 Dodge Neon R/T transmission problems.
Old Jan 14, 2013 | 10:50 AM
hatchetR/T's Avatar
I have a 2004 dodge neon r/t 5spd does anyone know the difference in the transmission codes 4668980,5273250AB, and 5273250AC besides the price.
I'm asking because mine transmission has stopped letting me shift into 4th,5th and reverse gear.
If anyone could help me out with this that'd be great
Old Jan 14, 2013 | 11:34 AM
Maybe some bad syncros.
I know that 5273250AC is the superseded part number (latest and greatest) of the orginal part number 5273250AB.
I read somewhere though that the shifter arm of the SXT version (5273250AC) is shorter than that of the R/T trans which would be the 4668980 or some version of that. I believe that there is a gear ratio difference between the two trannies as well. If you do a lot more highway driving, the STX version is more gas friendly than the R/T version.
Old Jan 14, 2013 | 12:00 PM
hatchetR/T's Avatar
Thanks for the info. I just know the dealership was saying one of those 3 go to that my car and I was hoping that they might be interchangeable.
Old Jan 14, 2013 | 01:11 PM
Check and replace the shifter linkage bushings !! common problem
Old Jan 14, 2013 | 01:14 PM
hatchetR/T's Avatar
i actually just replaced the shifter cables on the car going froms the trans to the shifter. the problem started a month after that
Old Jan 14, 2013 | 01:25 PM
bushing replacement
http://www.boogerracing.com/boogerbushings.html
Old Jan 14, 2013 | 01:30 PM
hatchetR/T's Avatar
they came with new bushings when i replaced the cables the dealership said i couldn't jut buy the bushings for the sry i wasn't more specific in my reply to you
Old Jan 15, 2013 | 02:11 AM
Bring the VIN to the dealership and they can tell you exactly what your car has for a tranny.
How many miles on it?
Old Jan 15, 2013 | 04:29 AM
hatchetR/T's Avatar
I did the vin number with the dealership over the phone yesterday afternoon and that's what narrowed it to those 3 numbers because they all fall under the t350 category. Also it has right around 130,000 miles
Old Jan 15, 2013 | 07:30 AM
You can't get the tranny into 4th, 5th or R? Even with playing and forcing it? I'm leaning towards the syncros needing to be replaced.
If you want to replace the whole tranny, I would go with the first number as that seems to be the tranny used for the R/T models.
Old Jan 15, 2013 | 05:04 PM
mr340's Avatar
I would take a real good look at the shifter and cables before diving right into a trans. Were the replaced parts from Mopar or aftermarket? were all the cables the same length as the originals? are they properly locked into the trans levers? I know these seem like dumb questions, but look at the obvious first. You say you just replaced them and the problem was not there before, what was the reason for replacement?
Old Jan 15, 2013 | 05:32 PM
Even the new bushings could be bad ? CHECK them again
xvodysseusvx
Jun 25, 2018 04:38 PM
allengreen
Oct 17, 2014 08:34 AM
71mopar
Nov 13, 2013 10:02 PM
Yellow04r/t
Mar 18, 2012 12:25 PM
iowapf
Jan 2, 2012 01:02 PM
