318 LA in a 57 Belvedere
Old Jan 7, 2012 | 09:06 PM
mcinturff's Avatar
My friend has a 57 Belvedere that he recently pulled the original 301 A motor out of and was given a free 318 LA out of a 69 Charger. The 301s crank sticks out further so that the torque converter can be bolted to it (the torque converter has studs, I believe it has no flex plate or is pressed together as a single unit). The 301 has an 8 bolt pattern, the 318 has 6. Can he use the original transmission? I believe it is a powerflite, push button. Is there a torque converter and flex plate combo that would make this all bolt together? If not, is there a way to drop in a torqueflite and make it use the push button linkage?
pipdog69
Mar 21, 2011 03:04 PM
s13saru
Mar 20, 2010 12:49 PM
s13saru
Feb 21, 2010 04:08 PM
s13saru
Feb 6, 2010 10:42 PM
mitchs66
Jan 31, 2010 08:52 PM
