4 speed tranny question
Old Sep 8, 2012 | 03:08 PM
Leem's Avatar
Can somebody tell me what 4 speed tranny was used behind a 340 or 360? Is it an A833 like the big blocks used?
Thanks,
Marty
Old Sep 8, 2012 | 04:14 PM
Yes all were 833 But there were differences. Input spline- Output shaft length, shifter position are the main difference. Now the later Aspen-Volare 4 speed is a 3 speed with 4 being an overdrive
Old Sep 8, 2012 | 04:32 PM
Leem's Avatar
Thanks for the reply.
Marty
Old Jan 30, 2013 | 04:55 PM
The whinning could be cheap gearset or improperly set up differential.
Old Jan 30, 2013 | 05:42 PM
4th gear was same on all transmissions You could swap to the later Volare style for slight overdrive, change the rear to 3.23 or slow down
wines out ? I think he is referring to too many RPM's
Old Jan 30, 2013 | 07:37 PM
Just a little bit of history and ratios:http://www.allpar.com/mopar/transmis...ed-manual.html
If either of you want lower rpm try larger diameter rear tires.
lgad
Feb 6, 2012 04:14 PM
afro
Feb 24, 2011 12:41 PM
jjg73
Jan 21, 2011 06:13 PM
joel
Feb 22, 2009 07:07 PM
soulkithchen63
Apr 6, 2008 08:12 PM
