727 E body gearshift control bracket
Old Jul 6, 2015 | 05:05 AM
73challenger360's Avatar
I have a 73 E body that had a 904 and floor mounted shifter. Im swapping to a 727 when I noticed the (replacement) 727 does not have the tab under the tailshaft to bolt the bracket to hold the bottom of the gearshift linkage in place. The 904 has the tab right below the speedometer cable hookup that is cast as part of the transmission casing. My 727 does not. It certainly does not appear that it was ground off of the 727 and no evidence it broke off either. The 727 did come from a 75-76 Dodge pickup. Does that matter? And is there a bracket to use to make this work in an E body?
Old Jul 6, 2015 | 10:13 AM
JS23's Avatar
I think the truck trans were slightly different in the tail shaft. (or maybe that was only the 4-spd?) How long is your tailshaft?
Old Jul 6, 2015 | 10:31 AM
I will have to go measure to be sure but I think it was approximately 4" longer than the 904's tailshaft??
robert24
Jun 15, 2014 07:58 PM
Inspector71
Oct 15, 2013 01:26 PM
7highboy7
Apr 20, 2013 11:48 AM
73cuda
Apr 19, 2010 04:09 AM
upnorth52
Oct 23, 2008 09:07 PM
