727 tans shaft
Old May 6, 2014 | 07:43 PM
440 aspen's Avatar
727 tans shaft
anybody know where I can get a bb 727 trans shaft? Im pretty sure I broke mine in half and I have to get a second car (this is my daily driver) and was hoping somone could giud me in the right direction. If I cant get the shaft alone then Ill save up for an a833 or something with an overdrive. Nay help would be appriciated
Old May 6, 2014 | 07:51 PM
Local Driveshaft shop can fix you up....
Old May 7, 2014 | 11:28 AM
??? You need a drive shaft ? or a trans output shaft ???
Old May 7, 2014 | 04:49 PM
pro-tech's Avatar
Transmission shop should have one laying around... or a bone yard...
Old May 8, 2014 | 07:32 PM
440 aspen's Avatar
Trans shaft. My drive shaft is fine. I was driving home from work not getting on just cruising, and I heard a loud pop and lost all of my gears and park. not the torque converter because I can still start my engine.
Old May 8, 2014 | 08:39 PM
Have you actually checked it ?? I lost my trans forward gears ?? broken wave washer snap ring... 727 Big & small block are probably the same. Be careful of the year because there are some differences.. Un bolt the drive shaft and turn it ?
newcuda
Feb 5, 2014 08:52 PM
1stimer
Apr 14, 2013 06:10 PM
72D100dodge
Apr 15, 2012 07:15 PM
furyaboveall
Oct 2, 2010 08:04 AM
furyaboveall
Nov 22, 2009 11:51 AM
