9.25 Pinion Preload Shimming.
Old Jul 16, 2013 | 03:11 PM
With Ratech 4109 solid pinion spacer.
.032" shims = 0"lbs.
.025" shims = 50"lbs (with seal)
.028" shims = 25"lbs (with seal)
Thought I'd share this info after my son just did ours and before building I had no luck finding shim thickness to tension info anywhere.
The adjusting tool for differential backlash and preload we made ourselves from 1" bolt 1 1/2" hex head ground slightly on the flats only to fit the odd shape, welded to pipe and short 1/2" extension.
Old Jul 17, 2013 | 05:13 AM
Good to know! Thanks!
maca
Jun 27, 2014 09:33 PM
aatkinsonalexdatkinson
Feb 1, 2012 08:13 AM
jdhyatt21
Jun 23, 2011 04:11 PM
thedusterridesagain
Mar 7, 2010 03:57 PM
snik
Sep 18, 2009 06:40 PM
