a518 on 85 360 la
Old Jan 13, 2013 | 03:02 PM
85dodgeram350's Avatar
a518 on 85 360 la
i have a 92 a518 in a 85 dodge ram and its bolted behind a 360 the tranny came out of a d150 with non lockup converter and the old 727 kickdown linkage and it has a holley street avenger 670 and i feel like it doesnt down shift easy enuff if i slow down then hit the gas it just doesnt down shift unless it punch the gas how should i adjust the kickdown so it down shifts earlier and its a rod style not cable thanks ahead of time advise much appreciated
Old Jan 13, 2013 | 03:10 PM
bigblock's Avatar
You cant adjust the linkage to fix that. A shift kit may have what you need. Consult with Summit Racing or Jegs.
Old Jan 13, 2013 | 05:10 PM
IT is adjustable.. Either at the trans or at the carb..
Old Jan 14, 2013 | 07:50 PM
Ok thanks and I know it's adjustable I didn't know witch way to go with it
Old Jan 14, 2013 | 08:19 PM
Gorts 5th's Avatar
Smile
i put a kit in mine but the linkage should be adjusted to the rear
the arm pushes back to increase trany fluid pressure. should cause a kick down but if you want a more street/strip feel then a shift improvement kit is the ticket i used a ATC reprogramming shift improvement kit.
Old Nov 24, 2014 | 06:57 AM
stoffy's Avatar
la 360 to a518
hi did you do this swap ? if so what did you do about converter weights flexplate ect. ?
Old Jan 4, 2015 | 01:16 PM
Gorts 5th's Avatar
Smile
You have to use the 360 tork convertr .... lock up is available check out my post big time swap the kick down govner.is adjusted by spring the shift improvment kit contains all the parts check out PACT.COM They have all parts needed
Old Jan 4, 2015 | 02:04 PM
moe7404's Avatar
the best place to get info. have known them since the late 60s. if they cant answer your Q no one can. http://www.areds.com/
orangesteve
27
Apr 8, 2013 02:59 AM
maca
Jan 20, 2013 02:49 AM
maca
18
Jan 14, 2013 04:24 AM
85dodgeram350
Oct 31, 2012 05:38 PM
erwatt
Feb 12, 2009 03:45 PM
