A833 Overdrive on 493 stroker?
Old Jul 15, 2014 | 12:13 AM
shone190's Avatar
Smile A833 Overdrive on 493 stroker?
Hi guys,
what do you think about A833 overdrive trans with aluminium housing, bolted on 493 stroker (525HP/590ftlbs) in 1973 Charger?
This will be weekend/holiday car, no drag races off course
Will it hold this power or not?
Thanks in advance.
Old Jul 15, 2014 | 09:14 AM
Just depends on how big your foot is. I'd say "no."
Old Jul 15, 2014 | 01:53 PM
Just don't wing it and side step the clutch... But as a driver it will be ok..
Old Jul 15, 2014 | 03:59 PM
Mr.4spd's Avatar
Is it a stock trans. or is it a Passon prepped unit? I run a 499 stroker and an 18 spline A-833 "Hemi" gear box, and I've blown the transmission up twice. While it does depend on your driving habits, you've got to keep in mind what the O.D. trans was intended for, and what a stroked big block is intended for. Unless Jamie has had his hands on it, it is not going to last long.
Old Jul 21, 2014 | 10:33 AM
DodgeAddict's Avatar
Looks like a new subject for Mythbusters as I know for fact a baasically stock 70 440 will explode the aluminum case
Why have a 493 (there's some reason for a big inch motor)& put a weak link between it & the rearend which I bet was built or installed to hold the 493
Jamie could hold prayer over the 833 OD & an exorcism too but that won't make a trans designed for a /6 or smog 318 The almighty trans
Old Jul 21, 2014 | 03:21 PM
Mr.4spd's Avatar
I heard he was putting together a833 od trans' that could take big power. Check out his website.
Old Jul 22, 2014 | 12:07 PM
It would take a new main case as the aluminum is weak Jamie has been working on his new trans more than the 833 OD from what I've been reading
He & I are members of the same forum he posts on a lot
Old Jul 22, 2014 | 01:42 PM
Mr.4spd's Avatar
Word
shone190
Jul 23, 2014 06:29 PM
cudaboy68
Feb 26, 2013 05:02 AM
bigmanjb
Jan 11, 2011 02:41 PM
teedeej340
Dec 7, 2010 09:15 AM
1966sportfury
Jul 6, 2010 04:27 PM
