Can rooster comb be adjusted?
Old Sep 14, 2022 | 01:03 PM
callmebob's Avatar
I have a 66 Barracuda with a A904. It will not start in park but will in neutral. I have tried 2 used and 2 new NSS's and still have the problem. The trans is a new rebuild. I dropped the pan and shifted it thru all the gears and noticed when in park the rooster was not and could not reach the pin in the NSS to activate it in park. The rooster hits the stop components before it can activate the NSS. So is there a way to adjust the rooster comb inside the trans?
Old Sep 15, 2022 | 11:49 AM
callmebob's Avatar
Found the problem. The arm on the manual shift lever ( rooster comb ) that goes to the manual valve was bent so not letting shifter go all the way into park. Replaced with the comb from my parts car, now all works good.
Old Sep 16, 2022 | 09:11 AM
Awesome !!!!! Thanks for the update... I would have never guessed that was the issue.... Mopar on !!! Cheers
DanZan
15
May 27, 2021 02:03 PM
inri
Aug 25, 2019 07:21 AM
Jhayessd
Jun 17, 2017 07:05 AM
Jhayessd
Jun 17, 2017 06:58 AM
anthony oborny
Jan 10, 2010 06:06 PM
