Conversion U-joint between driveshaft and differential?
Old 11-07-2014, 11:50 AM
shone190's Avatar
Question Conversion U-joint between driveshaft and differential?
Hi guys,
I have 1973 Charger and want to change U joints but can't determine which one is between differential and driveshaft. The one between driveshaft and transmission is NEAPCO 2-3050 (7290 Detroit/Spicer 1330)
http://www.thirskauto.com/vehicle-re...ea_2-3050.html
The other, between differential and driveshaft, is mystery to me Here you can see u-joint dimensions.
Cap diameters are 1.078" and 1.063", and I found these:
http://www.summitracing.com/int/parts/mog-457
http://www.summitracing.com/int/parts/mog-319
Problem is that other dimensions don't fit, I mean on u-joint width/height.
My old u-joint is 2.44" x 3.15"
First one from Summit is 1.125" x 3.622"
Second from Summit is 1.125" x 3.218"
So, what do you think, what u-joint I have
Old 11-07-2014, 12:57 PM
DDodger's Avatar
What sort of rear axle? "All Mopar?" Or adapted that might be out of Ford, etc? like a Spicr, etc?
There was one odd joint about 66? or so in the spicer rear ends
Old 11-07-2014, 01:03 PM
That size sounds like it might have been upgraded.... I Dont have time at the moment to look for the cross reference for you. But check Precision u joint spec and or the Dana/Spicer spec catalog....
Old 11-07-2014, 05:21 PM
My first guess was 7260/1310.
Is the 3.15" measurement inside between the clips?
Look up Neapco Catalog pdf, and you'll find all dimensions, I had a quick look and couldn't find 3.15".
Old 11-07-2014, 09:51 PM
shone190's Avatar
Yes, 3.15" is between the clips and I couldn't find any u joint with that width.
Old 11-08-2014, 04:10 AM
This might help...
http://www.driveshaftspecialist.com/...D%20Guide.html
http://www.iedls.com/
Old 11-16-2014, 08:57 AM
shone190's Avatar
I solved the problem and it was my mistake while I measured the joint, it is DETROIT 7260 - SPICER 1310
Thanks guys.
Old 11-16-2014, 09:18 AM
Cool Beans...
j57little
08-23-2015 01:53 PM
norcalitwin26
06-05-2014 02:16 PM
Phatchanz
07-01-2013 12:40 AM
Commando
04-12-2010 09:45 PM
atowncris
11-19-2009 12:48 PM
Quick Reply: Conversion U-joint between driveshaft and differential?
