P0700 Code Trans Problem Diagnostics Help
ok... Got a tough nut to crack....lol
2003 Ram 2500 4X4 5.7 Hemi A.T. ???
This is a truck thats out of my reach, Playing Phone tech.... Ya, i know
Trans shows a P0700 code.....
Trans Dose not want to shift out of 1st gear.....
Trans Fluid service Done.
Check all Fuses Done.
Check to make sure wiring is all plugged in.. Done
Note: there is no scan tool near to test.....
GAME ON.....
What would you do next? Or how would you attempt to fix it.
Sol. pack? maybe?
Thanks Guys....
GAME ON.....
Sol. pack? maybe?
Thanks Guys....
1st off how did you get the code with no code reader?
Did they quickly move the key on and off 3 times? and read the code in the dash?
the 0700 code is usually involves 2 sensors (governors) in the transmission under the pan. You can do the job but you best know what your doing.
if you remove the wrong bolts it will be a night mare.
My advise, take it to a tranny shop it should not cost all that much at all.
On the Dodge trucks that code indicates there are more codes inside the TCM. Most aftermarket scan tools don't have the capability to ready TCM codes (for some reason). Have the owner take it to a tranny shop.
- With the trans not shifting out of first, does this also happen when you put it into manual 2 and manual 3?
- Does it feel like there is any slippage while in 1st?
- Was the tranny fluid flushed or just drained and filled?
- How many miles on the truck?
No DRB-3 scan tool nearby...
Thank You for your input....
2- Driver say's it hold 1st gear well.
3- Just Drained and refilled... Fluid was not burnt or discolored, No filter change needed. No hard material, Not much soft lining, Fairly clean in the pan..
4- 145,000 miles.....
Bob, It is not stuck in 1st gear it is in 2nd gear and it is in limp in mode...You need a scan tool to properly diagnose the problem..But if you have just serviced it you might have fixed the problem. Un hook the battery for an hour or overnight is better. Then give it a test drive to relearn everything.. It would be better if you have the tool to clear the codes...Bill
Thanks Guys for all your input..... Looks like I am headed out of town this weekend to fix this truck.
I'll be taking my Snap-On Modus with me.... What a great tool...
The things we do for our kids.....
Today i got all the schematics together...
Now..were is that tape..... Oh here it is....
We have had a lot of comp probs lately. Meaning we replace a lot of them then have to take it to the dealer to get programmed. But you better get it scanned by a good shop before you do anything. Wiring probs can cause codes too,which is the leading prob with late model Mopars.
UpDate: Road Trip did not go so well.... The truck will only move forward in 1st gear, That's it. The truck dose have revers. But as soon as you drop it into drive, You have to throttle it just slightly for it too jump into first gear.
I could not scan the truck.... It appears that someone forgot to tell me of some other electrical issues.
So I advised him to being the truck down to where I am at so I could look into the problem further. That's a 4.5 hour tow.
Any How here are my thoughts..... It is ether...
1.the electrical issue mess with this thing...
2.The Trans coil pack....
3. It broke the snap ring or pin on the drum...
I'll up date Y'all if it makes it down here for me to fix.....
opcorn:
So I advised him to being the truck down to where I am at so I could look into the problem further. That's a 4.5 hour tow.Any How here are my thoughts..... It is ether...
opcorn:
Well the truck has made it down here from up north....
We have got the Electrical nightmare fixed.....
(You have to remember. This was the 1st year for the 5.7 Hemi in these truck. All this stuff was different than all the other models)
As for the trans problem: So far here is where I'm at...
PO700 Trans Controller fault
PO731 Gear Ratio Error in First
PO1790 Fault Immediately after shift
PO876 Under Drive pressure switch Sensor Curcuit
PO841 Low Reverse Pressure switch Sensor Curcuit
Just a reminder the driving condition for this was:
truck moves in reverse...
Truck goes into 1st gear only... However you have to give it just a little throttle to make it catch. And it wont come out of 1st gear no matter what you Do.....
Going to start checking all the code by there diagnostic procedures and then if that dose not show any good results, a full new coil package and wiring harness... Well see what happens from there...???????
Just food for thought.....
Most of the time, these vehicles will go into a limp mode which puts them in a second-third gear mode too get home in.
This one is positively stuck in low gear when in forward range.
Come on Gentlemen....this is the way you fix them....RITE?????
Oh my...... I Pulled the trans pan off...... 2 broken bolts lying in the bottom of the pan... and a chit load of material lying in the pan.... This thing is toast....
Called my local buddy and off to the trans shop it goes....Told him to put in all the new updated stuff he could..And a external filter..... Called me back and said $2,500.00 out the Door....
So the solenoid bolts were broken ? $2500 sounds like a lot for a buddy price..
I went through the airport once with my Dodge van with a car in tow on a dolly..
UpDate....2003 Dodge Ram 2500 4X4 5.7 Hemi A.t.
Well this turned into a nightmare.. Going to give you the short story.....
Trans was taken apart and what was found..... One of the spool valves got loose from the valve body? (Dont ask me how that could happen Cause I sure the Fk dont know) Thats what toasted this trans...
So this trans got a complete O.H
Clutch's, seals, plates, Valve body, solenoids, sensors, coil packs, wiring harness, convertor, in-line filter.
Now with the Combo of the Reman 5.7 and a overhauled 45RFE trans...
And after spending 8,000 buck....
This truck is ready for the road again.....
Man the things we do for our Kids......
Rumblefish318
Jun 26, 2013 05:24 PM
