Rear Differential...
Old Oct 12, 2012 | 04:12 PM
oldiebutgoodie's Avatar
We took the differential cover off today to replace the gear oil. and to take a gander at the rear end gears...I took a picture of it...maybe someone can tell if it is the LSD differential or something different in there ...I didnt even think to count the teeth to find out what gears are in it (if thats even how you could tell?)
Old Oct 12, 2012 | 04:56 PM
That is definitely a sure grip.. Early clutch type ??
Old Oct 13, 2012 | 05:13 AM
Sometimes on the ring gear it'll have the teeth count of the ring gear and pinion. Looks like a two part case (could just be the picture though). 8.25 rear axle huh? When you fill it back up, you may need the "limited slip" additive, that goes in before the gear oil does.
TVLynn - It does look like an early clutch style. I've noticed that these last longer (wear wise) than the later clutch style. It looks like a stock unit to me. Someone could have swapped it in from another 8.25 rear axle vehicle or it could have come from the fatory like that.
Old Oct 13, 2012 | 02:09 PM
I understand there is some kind of thrust button that you have to watch for if you remove the axles too. The clutch type is rebuild able unlike the later cone type
Old Oct 14, 2012 | 06:54 AM
Gorts 5th's Avatar
Smile
did you use the proper additive for the sure grip clutches
had a friend rebuilt his and didn't put in the posi additive his clutches failed 3 month later
Old Oct 14, 2012 | 09:19 AM
Did you put the posi additive in there?
Of course not Just put 80w-90 in it....Luckily we just went to town and back in it (14 miles.) Whats that stuff called? ( just posi-clutch additive?) I will call around and see who has it...maybe Napa.. Thanks for the heads-up on that Gorts 5th & 78D200...We Sure don't need no major Failures at this point in the game...I have enough to do on the truck without re-building the rear-end also....
Thanks to: TVLynn, 78D200, Gorts 5th.......
Old Oct 14, 2012 | 10:50 AM
Heya Gorts 5th, I found some at our local Napa...Its "TRANS-X" brand...7 ounce bottle...Thanks again man...
Old Oct 14, 2012 | 12:40 PM
Good call Gorts, this is the way this stuff is suppose to work. I Love this place.
Old Oct 14, 2012 | 02:35 PM
You and me both my friend..
Old Oct 14, 2012 | 05:13 PM
Gorts 5th's Avatar
Smile
thats right brother we all need help it costs to much to screw up today any suggestions that i can get is very help full thats why im here we look out for each others
Old Oct 14, 2012 | 06:58 PM
All my mopar brothers that I never had....LOL thanks again...
Nightmare
Sep 25, 2012 12:34 PM
Mudslinging
Aug 14, 2012 02:23 AM
Barfly
Mar 1, 2011 02:39 AM
67gtxclone
Apr 7, 2010 01:56 PM
danuwells
Aug 5, 2007 10:58 AM
