Rear end leak
Old Aug 28, 2013 | 05:06 PM
Shrug's Avatar
Rear end leak
OK, how do I get this to stop leaking? What are the steps I need to take and the parts I need to get??
I would appreciate any info!
Old Aug 28, 2013 | 05:29 PM
Need to remove the drive shaft. There is a procedure. You need to check it before taking it apart and see how many inch lbs it takes to turn the pinion . Then Remove the pinion nut and flange and replace the seal Bolt it back up & re torque in steps try to get the same in lbs reading you got before From the looks It probably needs a re build so
just replace the seal & re torque and hope for the best
Old Aug 29, 2013 | 09:19 AM
Shrug's Avatar
So does anyone know where to get this seal? I have been looking all over.
Old Aug 29, 2013 | 12:13 PM
We need more info ! but looking for 62 Dodge 8 3/4 pinion seal ???
SKF18708 looks like a good prospect. When you get the old seal out there should be a number on it that can be crossed
http://www.ebay.com/itm/ws/eBayISAPI...m=370884808243
Old Aug 29, 2013 | 01:12 PM
Napa Auto Parts.....
Old Aug 29, 2013 | 01:58 PM
Shrug's Avatar
D'oh! It is a 1952 Plymouth Cranbrook
Old Aug 29, 2013 | 02:35 PM
OK 52 National seal 7216 for 52 Dodge . I would suspect it is the same one used for Plymouth Check on www.RockAuto.com It's listed
Old Aug 29, 2013 | 04:08 PM
Shrug's Avatar
Thanks, I will check it out!
fastdakota84
Jul 26, 2010 02:46 PM
DandyD
Apr 19, 2010 02:48 PM
72_coronet
Jan 12, 2009 05:57 PM
thekinzuakid247
Apr 3, 2007 07:37 AM
thekinzuakid247
Mar 25, 2007 01:56 PM
