Shifting issue
Old Jun 29, 2018 | 05:05 AM
Daren's Avatar
Shifting issue
Hey there and thanks for reading my post I have a 1973 dodge charger with a 727 torque flight transmission I recently replaced the pump seal and rear output shaft seal and it worked perfectly no leaks but the next day I went to fully take her out and my shifter is not working the car is in drive and wont shift to anything else even neutral not sure if this helps but the key wont start the car either I have to turn the key forward and pop the hood then proceed to touch the starter cylinoid with a screwdriver does anyone know a solution to fix the shifter thanks for any help
Old Jun 29, 2018 | 06:35 AM
Shift linkage and column lock linkage.
Old Jun 29, 2018 | 11:48 AM
Daren's Avatar
Thank you is that relatively easy to fix?
Old Jun 29, 2018 | 05:54 PM
Straight forward with a service manual. Possible look up at For B Bodies Only.
Old Jun 30, 2018 | 04:06 AM
Daren's Avatar
Thanks again for the assistance I will update you and let you know if I resolved this.
Old Jun 30, 2018 | 05:17 PM
http://www.mymopar.com/index.php?pid=168
demetri
17
Feb 15, 2015 10:18 AM
koondawg_74 roadrunner
Jul 22, 2012 06:51 PM
MilesP
Feb 26, 2012 07:19 PM
64fury
Feb 2, 2010 06:25 PM
72D100dodge
Nov 4, 2009 11:42 AM
