Wanting to put a small block overdrive transmission with a 440
Old 03-10-2017 | 07:45 PM
Playtime's Avatar
Ok, I've never posted so here we go. We are wanting to see if anyone has done or has heard of adapting a small block transmission to a 440 with 4 wheel drive. We are running in a pulling truck so by no means is it factory. Any thoughts or ideas?
Old 03-10-2017 | 09:51 PM
Gear Vendors overdrive
Playtime (03-11-2017)
Old 03-10-2017 | 10:24 PM
Are you swapping a 440 into a truck with the OD already?
Old 03-11-2017 | 07:05 AM
Playtime's Avatar
Yes, the truck does have overdrive.
Old 03-11-2017 | 11:27 AM
Sounds like you need a 727 and whatever transfer case that works with it, and like was stated before a Gear Vendors overdrive.
Old 03-11-2017 | 04:11 PM
Playtime's Avatar
really trying to keep the same gear ratio. I know they make an a​​​​​dapter plate that will connect the 440 to a newer model small block overdrive transmission. Has anyone else? If so, have you had or heard whether works well, not so well or any thing else?
Old 03-11-2017 | 04:54 PM
​​​​hey my moto is ?
RRR01
04-11-2016 01:35 PM
sendust
09-02-2014 03:37 PM
pipdog69
03-14-2012 12:01 AM
raindance654
04-04-2010 01:13 AM
mahd
04-02-2009 10:05 AM
Quick Reply: Wanting to put a small block overdrive transmission with a 440
