1999 dodge intrepid 3.2 v6
Old Nov 3, 2019 | 09:12 AM
Asan's Avatar
It’s been sitting since 2011 been moving lil not much. It has ABS light on can I reset it without scan tool
Old Nov 3, 2019 | 10:48 AM
If its a "soft code" Once you fix the issue with the ABS system. You can drive it and it will clear on its own. But fit it is a "Hard Code" Then you will need a scantool to clear the fault.
Old Nov 3, 2019 | 11:01 AM
Asan's Avatar
Intrepid
It has about 15-20 codes. There’s air in the system the front drivers side caliper bleeder screw is seized. Plus the car brake lines rusted and replaced them all the way around
Old Nov 4, 2019 | 07:47 AM
Oh My... That sounds like a fun one to fix.
Old Nov 4, 2019 | 03:12 PM
Asan's Avatar
But it starts right up. No check engine only thing is abs.
gwgdog66
Jul 26, 2017 02:40 PM
jaygr
Oct 24, 2012 02:39 AM
Daniel Albert
Jul 21, 2012 07:22 PM
CantRamItDodgeIt91
Jun 12, 2010 10:43 PM
Skunk Ape
Feb 3, 2009 01:28 PM
