Front disc brake recommendations
Old Mar 16, 2016 | 03:40 PM
Carguy's Avatar
Have a 1963 Dodge 330 and want to replace front drums with disc brakes. Have dual master. Rear drums. Wanted to do Wilwood but my stock steel wheels have a 2.75 inch center hub hole while Wilwood needs at least 3.10 inches. So, what other tried and true front disc brakes do members recommend that by far are the best second choice, and preferably made in America? Please advise so I make the correct selection on this all important decision. Thanks.
Old Mar 16, 2016 | 06:02 PM
Check with SSBC and ask them if they can put a kit together for you....
http://ssbrakes.com/
I'm Not Sure if the Polara kit will fit or not???????
Old Mar 31, 2016 | 02:27 PM
Carguy's Avatar
I checked with SSBC and they didn't know either. Oh well.
Old Mar 31, 2016 | 02:54 PM
Might Check with Strange and see what is offered from them.... Just a thought.
Speedway clams there kit will fit.....
http://www.speedwaymotors.com/Shop/S...e-Kits/33.html
Old Apr 25, 2016 | 06:47 PM
Carguy's Avatar
Thanks. My owners manual is for a Polara and 330. Seems to me these are one in the same B body cars with different names. SSBC has some nice options if they would only know what they fit. Can't believe I'm the first one in the world to ask if the Polara kit will fit the 330. Maybe so. Speedway does look like a fit or they just know what they are doing more so than SSBC. Thanks
Old Apr 25, 2016 | 09:11 PM
I'm sure someone has done that swap.... I dont know off the top of my head...
But Im sure its out their...
Old Apr 25, 2016 | 09:20 PM
Found this kit....http://www.classicindustries.com/pro...ts/md7785.html
But you will have to change wheels.....
Maybe vintage wheel can fab you up the rite center "look-a-likes?????
Food for thought....
Old Apr 26, 2016 | 12:38 PM
Carguy's Avatar
Was hoping to use my existing spindles, but that doesn't seem possible. Thanks again.
bruger
Jul 16, 2010 10:14 AM
Rbaisch
Dec 1, 2008 02:17 AM
bgreene30
Sep 1, 2008 01:40 PM
bgreene30
Nov 23, 2007 09:08 PM
bgreene30
Nov 17, 2007 10:39 PM
