How to remove broken bolt from machines
As we are dealing with heavy duty machines so it is not necessary that position always remain same, we are facing this problem on large scale and want to hire a particular firm for this task. Can you give me such name of firms?
It depends on how it is located and on the bolt itself.It also depends on how it broke and access to the place as well.
remove broken bolt
remove broken bolt
If the head is broken off, and the rest of the bolt is sticking out a little,you can weld a one zize bigger nut on it. Then spray on some rust solvent. The heat helps it to penetrate. Have done this two times with success.
I have a set of drill bits that work in a reverse rotation to cut. So you run your drill in reverse but they cut in the counter clockwise position. As they cut they are also torking the bolt out. This preserves the threads in most cases and removes the bolt.
